Question about Panasonic Televison & Video
Don't have original remote for Panasonic tv. Replace lamp came on screen, so I ordered new lamp and put in , the message still comes on screen. How can I reset hour timer with universal remote
4 Suggested Answers
  • 81 Answers
SOURCE: resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Posted on Nov 19, 2009
SD Tech
  • 14553 Answers
SOURCE: can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Posted on Mar 26, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a Panasonic pt-61lcx65 tv and just replaced
I think you are going to find a Panasonic remote like the original one is needed.
Posted on Aug 27, 2012
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How do you reset the lamp clock on Panasonic model number PT-61LCX35 without an original remote?
We regret to inform you the original remote is necessary to reset the lamp hour meter. We recommend you use the below link to obtain the correct remote control for the TV. The remote part number is EUR7627Z70.
Parts Ordering
Mar 17, 2014 | Panasonic Televison & Video
How do i remove the black box on my screen
don't have the original remote control, I used the time warner control, I just reprogramed to control my tv without the cable box, I put the volume all the way up in the tv, then down to zero, and at the same time I hold the 0 key in the remote control, after that the screen said lamp has been reset to zero, I repeated this step because a lamp red light stayed on, after this only the power green light only stays, when installing the new lamp make sure is all the way in, you can use the white out to mark exactly where you have to push or put in the new lamp, it may not been all the way in, hope this help someone !!
Jan 18, 2012 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Same problem
You mean physically replace the lamp or reset the lamp timer?
To replace the lamp, you unplug the TV, take the front cover off of the TV under the screen, open the little door, unscrew a screw, then pull a handle that will pull out the entire lamp assembly.
Shove the new lamp assembly in place, reattach the screw, shut the door, snap the panel back on, and fire it up.
To reset the lamp timer you have to have your TV remote (not a universal - the original remote). Turn the TV on and wait for the lamp timer reset message to disappear or push Exit on the remote (or any button similar to exit, depending on the model).
Then, simultaneously press and hold the VOL- button on the TV and the PIP button on the remote at the same time (usually near the bottom left of the remote). On some models it is the SPLIT button instead.
IRT the other answer, there are more than one type of rear projection television. The one's you have seen with three lamps are CRT-based and have one CRT for each primary color of red, green, and blue. Panasonic no longer makes these and any issues with the lamps must be referred to an authorized servicer. Therefore, I conclude in this case that the question is in reference to a DLP or LCD rear projection display.
Aug 22, 2009 | Panasonic PT-44LCX65 Television
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Lamp Replacement
take the panel off of the bottom front of the TV - under the screen almost at the floor - with your hands. unscrew the screw on the caution statement and open the panel. you'll see a handle and another screw to the right of it - loosen that screw (it doesn't come all the way out - or shouldn't, anyway). slowly pull the handle until the lamp comes out - if there is busted glass, clear that out. Slide the other lamp inside the television the same way and power back up.
This should work, however - there are a couple of things to cover:
-If you ordered the lamp from Panasonic it would have come already in the assembly. If you ordered it elsewhere it may just be the bulb. If that's the case, you will need to assemble it yourself of have someone do it for you. You do not want to get oil or fingerprints on the bulb as this will significantly reduce it's lifespan.
-You may want to reset the lamp timer in the television once you get the new lamp inserted. First you have to have the television powered on and no messages or menus on-screen from the TV. Then use the original remote and take it to the television, make sure it's in TV mode and aimed at the IR sensor. Then, press and hold VOL- on the TV itself and PIP on the remote at the same time for 5 to 10 seconds. You should get a message that says "lamp time was reset to 0".
May 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic
replace with a new aire filter or clean the air filter
vkm
Nov 23, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
