Question about Fisher Dishwashers
Fault F24 in Fisher & Paykel Double Drawer Dishwasher
Krazytech
  • 725 Answers
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
Posted on Jun 16, 2008
  • 15 Answers
SOURCE: FISHER PAYKEL DISH DRAWER U3
LP is a setting for Low pressure. To reset your pressure to HP, hold the Programme and Eco touch switches simultaneously for 5 seconds. Once the setup mode is entered a beep is emitted and
the LCD is red with ‘HP’ or 'LP' displayed. Push the Start/Pause button to alternate between HP and LP. and push the power button to exit.
Posted on Feb 09, 2009
  • 81 Answers
SOURCE: reset fisher and paykel two drawer dishwasher
Have you tried turning it off and on at the power point?
Mat
Posted on Sep 24, 2009
  • 784 Answers
SOURCE: How can I empty some residue water from the Fisher
Go to diagnostic mode you can turn on the drain manually. The motor has 2 directions of operating: one for pump and the other for drain. When the LCD displays P1 it means wash, when it displays P2 it is for drain.
Posted on Nov 01, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Fisher paykel dishwasher
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
Jul 30, 2014 | Fisher and Paykel Dishwashers
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My Fisher Paykel dishwasher is flashing F1 - top drawer only. The bottom drawer is working just fine.
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Nov 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel twin draw
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
Jun 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Jan 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
359 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
