Question about Bernina Sewing Machines
My bobbin winder on my 1978 Bernina record electronic machine won't turn and wind the bobbin
    Top Expert:
  • Bernina Master
  • 8,248 Answers
Posted on Dec 09, 2016
  • Bernina Master
  • 12,031 Answers
Most like the machine has seized due to lack of oil over time. Frequently, the levers, selectors, and feed dog mechanisms are affected first, but it could also have affected the bobbin winding mechanism.
Wheel on right side that controls the needle up and down is very tight...
My Bernina 440QE will not wind a bobbin.
Hmm, I have a 440 bur have not had this problem. However, I do most of my bobbin winding on a standalone bobbin winder (called Sidewinder). They are available several places, JoAnn's, Amazon, etc. for about $30. You can get one that will take batteries or a power cord. Saves wear n tear on your machine, plus you can wind multiple bobbins quickly, and you don't need to unthread your machine. Just an idea.
Mar 01, 2018 | Bernina Sewing Machines
I have the Bernina Artista 180. It is not recognizing when I turn the bobbin winder on. Any suggestions?
For a quick fix and until you can get your machine serviced, pick up a Sidewinder bobbin winder (check to make sure your bobbins will work since the larger Bernina bobbins may not). I purchased a Sidewinder a few years ago and use it all the time. Saves wear-n-tear on the machine but also lets you quickly wind multiple bobbins without having to unthread your machine. Most Sidewinders are battery operated, but mine also has an AC adaptor for electrical usage too.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Sep 24, 2017 | Bernina Sewing Machines
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Bernina manual
Winder rubber is likely needing replacement
Feb 20, 2014 | Sewing Machines
Bernina 180 - winding thread onto bobbin spool
If the bobbin winder spindle turns freely by hand and the macine runs fine with the foot controller then it may be the small motor that runs the bobbin winder that is at fault. If this is the case then your local service tech should be able to relace it. It is not a very costly part so don't be to worried.
Nov 02, 2008 | Bernina Artista 180
Bernina 145 Bobbin winding problem
If the winder is working without thread as it should you can rule out an electronic and motor issue. At this point it won't hurt to remove the two screws on top and lift your top cover off. Take a close look at your winder and see if there is any thread or anything wound around or blocking it. There are one or two screws that will adjust the eveness of your bobbinwinding but I don't think this is part of the problem (just a slight turn for that until the bobbin winds evenly). There is a spring beneith the winder that may have popped loose, check that but if the little arm snaps back and forth thats ok. The spring should be in the second tooth of the gear notches.
I hope this helps.
Jul 19, 2008 | Sewing Machines
Sewing Machines Logo
67 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
