Heating & Cooling Logo
christin pierce Posted on Dec 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Purchased a used comfort zone tower heater for my granddaughter. And it ran everything perfect. Got it home only discovered it will only run for a minute then it shuts off and the LCD is blank
  • Christin Pierce
    Christin Pierce Mar 13, 2017
    bought it at an indoor flea market. They don't take returns. just need to know how to fix the fan myself.
Marvin
Level 3:
Top Expert:
  • Comfort Zone Master 85,242 Answers
  • Posted on Dec 09, 2016
Marvin
Comfort Zone Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025273
Points
266281
Take it back, any attempt to repair will void the warranty
5 Related Answers
Anonymous
  • Posted on Dec 06, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
tbugger
Jerry Magee
  • 232 Answers
  • Posted on Feb 06, 2009
SOURCE: reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Anonymous
  • Posted on Nov 18, 2009
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Just Add Tools
  • 7 Answers
  • Posted on Oct 02, 2010
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Mack Baxter
  • 383 Answers
  • Posted on Jan 15, 2011
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Comfort Zone CZ230ERG 7,500-Watt, 240v Hard-Wired Digital Fan-Forced Ceiling Mount Heater. Manual please model cz230erg 7500 watts heater.
Question edited for full 'make model (what it is)'.
Question moved from 'Watts Electrical Supplies' to Comfort Zone.
Manual
https://manuals.plus/comfort-zone/comfort-zone-cz230er-7500-watt-digital-thermostat
Comfort Zone Ceiling-Mounted 7500-Watt Fan-Forced ...
comfortzoneproducts.com https://www.comfortzoneproducts.com > products > ce...
Featuring a ceiling-mount design, this tough commercial heater boasts a heavy gauge steel body that stands up to daily use in poorly insulated areas where ...
2answers
My Comfort Zone cz260er is wired and there is juice to everything but no light when powered on and on/ off button does nothing.
please ensure that you've got the recommend voltage and current going to your device based on the product manual. If it's getting hot but not turning on, you could be doing everything correctly but the device is faulty. I would suggest next using the troubleshooting section of your manual before calling the manufacturer to ask for a possible trade-in of the device.
Thank you.
I have a comfort zone model CZ2011C. We have no heat all weekend til Monday .will these heaters be safe to run? Help!
The main issue with space heaters is either setting them too close to something flammable or them getting pushed over, They are supposed to have a tip switch in them though. The issue about drawing too much electric current could be a problem. Dont put them on the same circuit. They should not have any other concerns about running.;.
Comfort zone tower fan won't oscillate
Remove bottom and check if gear is stripped or very dirty so can't turn.
2helpful
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
6helpful
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
My comfort zone is not heating I had a infarared bulb that went out replace the bulb the heater still want come on it is hard to get techical support to tell what's wrong.
The bulbs on the older (pre-fall of 2010) Comfort zone heaters are in pairs... if one bulb of the pair is burnt out the other will not work. Also they are not easy to line up when replacing them back into the recepticle...they must line up perfectly to work.
Need to replace tip over protection switch
I have looked everywhere for this switch on 7 different models and there is not one place that sells this piece. Sorry about that
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
