Question about Samsung Tablets & eReaders
When streaming movies from my android Samsung tablet to my Samsung smart tv, it doesn't show full screen. I have tried using tv settings and also tablet settings to no avail. What am I doing wrong?
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
SOURCE: just bought a disgo 8000 android tablet but it freezes every time I try to use the gallery
We are sorry to hear that the device is freezing and not working as expected.
Please try the following which may help to resolve the issue.
1) Ensure that the Video/Image files you are trying to view are compatible with the tablet. Compatible files are located on the packaging and in the User Manual. You can also locate this information on the website,
2) If you have not already done so, we would advise that you update the device to version 2.3. The update procedure can be found at the following page;
3) If the Gallery app only freezes when accessing files on the SD card (and not internal memory), please try using the alternative memory card slot or test using a different memory card.
I do hope this helps to resolve the issue.
If you require any further assistance, please do not hesitate to contact us at
Posted on Jun 12, 2012
  • 329 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
Lg tablet and lg smart tv wont update downloading not supported 8. Now trying to view info in ancestrlgon tv error 400/404 could be cookies to big, what does this mean how do i fix
Netflix Streaming problem on LG Smart TV - Forums - CNET > Forums > LG
CNETJan 27, 2013 - I have an LG LM620T connected to the internet. ... streaming via wi-fi to my Google Nexus 7 tablet, using the same movies that lock on the TV. Unable to get smart view 2.0 to recognize my TV
Jun 11, 2015
LG Smart TVs for online video watching?
Aug 2, 2013
LG Smart Share Support
Mar 3, 2013
More results from
LG Smart TV YouTube App Crashing/Not working - Google Product Forums!topic/youtube/...
GoogleMay 20, 2014 - I have an LG Smart TV Model Number 47LM6200. ... TV YouTube App Crashing/Not working, Kevin Wrigley, 5/25/14 8:38 ... Can't even link the TV to the phone/tablet app for a screenshot ... Did it coincide with a firmware update or any other change? ...... I downloaded an update for the LG 47LM7600-TA . Trouble mirroring your Android Screen?
Mar 10, 2015
Anybody else frustrated with youtube app on "LG smartTV"?
Jun 29, 2011
More results from
LG Smart TV - Firmware Updates - YouTube
? 1:07
Feb 6, 2013 - Uploaded by ExperienceLG
LG Smart TVs employ firmware to operate their state-of-the-art systems. ... firmware wouldn't update on my 47 inch Smart TV, so I downloaded ... Jensen 8 months ago ... LG is not a good company, LG is not sending software updates on .... how to connect your laptop, android, iphone and or tablet to your tv ..
Jan 05, 2016 | LG 3D-CapabBray Disc Player with SmartTV...
Why do down loaded videos from Google and Disney not play? He can stream videos from internet, but not if tablet is away from internet.
Use Disney Movies Anywhere with Google Play - the ... > ... > Movies & TV > Features & settings
GoogleYou can connect your Google Play account with Disney Movies Anywhere and ... If theDownloaded only switch is red, tap it again to see all of your videos.
Disney Movies Anywhere - Android Apps on Google Play
Rating: 4 - ‎63,729 votes - ‎Free
Or download movies to watch without an internet connection. ... Disney content with your eligible purchases, including original programming, never-before-seen videos, and much more ... Wish you could link to Vudu I have a smart TV but there is no Disneyapp. ..... But the Android app login does not work on my phone.
WATCH Disney Channel - Android Apps on Google Play
Rating: 4 - ‎17,070 votes - ‎Free
WATCH MORE & PLAY MORE with WATCH Disney Channel! ... No worries. ... Before you download this experience, please consider that this app contains advertising for ... Live video and the newest full episodes are only available with a ... 5 minutes later it logs off or something then when i go back it does the same and ...
Disney Movies Anywhere Streaming & Downloading
Jan 03, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
Can I hook my tablet thru my wifi router or my cable box to stream internet TV on the big screen?
easiest way to stream to tv is with a cable. depending on the make of the tablet , you can buy hdmi micro cables to connect to tv. doing it wireless you will need a box plugged into the tv that has DNLA capability. both are available to buy.if you go for an android tv box they have that but also have XBMC which will allow you to watch any movie/tv programs/sports etc for free
Apr 28, 2015 | Tablets & eReaders
Need netflix account # to watch movies on my smart t v
most tablets have an app store. if you have one go there get the netflix app and then logon to your account if you dont have one you need to signup and pay $7.99 month for free movies. if you have a smart tv. then you need internet access to and keyboard to go to, unless your tv has this app program already on it. then its just a matter of internet.
Oct 01, 2014 | Samsung Galaxy Tab 2 Nd Generation 7 8gb...
How to connect tablet to tv
Buy a compatible HD cable. Depending on your device this may vary. If you have a Samsung tablet, it will connect to your TV if your TV is also a Samsung Smart TV.
Nov 27, 2013 | Tablets & eReaders
Android tablet screen freezes
I have an apple android tablet and it freezes at the android with black backround
Jan 26, 2012 | Tablets & eReaders
Tablets & eReaders Logo
29 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
