60 inchLG plasma problems
Was working with the odd flash of purple or violet then it went all blotchy for few seconds and shuts down
2 Suggested Answers
gopakumarg43
  • 75178 Answers
SOURCE: 60 inch lg tv was working with the odd flash of purple or violet now when it is turned on it goes completely blotchy for few seeconds and then shutsdown?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 10, 2016
LG plasma 60pv450 has stopped working. It turns on and after a few seconds it shuts off. I can't get it to turn back on. There is a standby light on.
The set is going into safety mode. This could be one of many problems and we would need to inspect the set.
Jan 05, 2017 | LG 60 60PV450 Plasma TV
LG Plasma 60PZ750-UG with no picture or sound.
This is a code for a power supply shut down.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 10, 2016 | LG 60PZ750 60 in. 3D HD-Ready Plasma TV
Dec 09, 2016 | LG Televison & Video
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
When I went to shut it down it had a few programs to shut down. I waited a few minutes then closed the lid down. It is now flashing on the first light symbol on the corner and when you open it up it turns...
Sounds like it is stuck in hibernate mode. Hold the power button down for 5 seconds and try to start it again. If it doesn't start remove the battery, unplug the laptop, hold the power button down for 60 seconds. Now plug in the power supply but leave the battery out. Turn it on. It should start now and you can re-insert the battery.
Apr 22, 2011 | Compaq Presario CQ60-212US Notebook
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Televison & Video Logo
Top Televison & Video Experts
