Question about Toys
Can I buy parts to fix the ladder on my Hasbro fire truck it won't go up and down the motor runs but it won't go up and down I need the gearbox can you buy the gearbox if so please tell me where
4 Suggested Answers
SOURCE: Auto Gearbox Sensor needs changing, but where do i buy it?
go to eEuroparts.com or saabsavoir.com. you will find one.
Posted on Feb 26, 2009
  • 239 Answers
SOURCE: truck broke down no fire.. replaced coil, ing
I recently had a similar problem. I drive a 94 ram 1500 with the 3.9 6 cylinder. When I replaced the coil it started right up but then cut out and wouldn't start. So I wiggled the wire that plugs into the coil and tried to start it and it fired up again and the next day it wouldn't start. My problem was were the wires connected to the plug came loss. I went to the junk yard found any ram truck from 94 to 01 with either gas engine 3.9-5.2-5.9 and cut the plug off with decent amount of wire and installed it on mine and problem was solved. I also had a catalytic converter problem about 3 months after that was similar but it would start right up and run in neutral fine but when it gear it would bog down and eventually stall. Good luck.
Posted on Jul 26, 2011
  • 5622 Answers
SOURCE: Truck won't start, f250 351 motor. 1997, it would
Check your ignition relay in the powerbox. Most Relays have numbers on them and Ford often uses the same Relay for the Horn. You can go to Autozone.com and register your truck for FREE and then make prints of your Fusebox and your entire Chassis wiring. Once you verify which Relay is for the Horn and Ignition, you can swap them and see if the horn works.
If the horn does not work, then the Relay was bad and you can use the former horn relay and stick it in the Ignition position and drive your truck.
I want to also point out that under the dash you will have a switch on the Brake pedal lever and on the clutch lever, that are lockouts for the starter. But when a foot hits them and moves them or breaks them, any type of connection is possible. You may still have a starter connection but lose other electric power.
If what we have tried still does not get you going; check the voltage going into your coil. You could just have a bad coil.
I looked up your engine and my records show either a 7.5L or a 5.4L and the last year for the 351 was in 1996.
Posted on Jan 27, 2012
The motor runs but the chain does not. The motor will turn off by itself.
not doubt the chain sprocket came loose either take it down to fix or stand on a ladder
Mar 17, 2015 | Building Materials
I just bought Volunteer Fire Truck # 1 at a yard sale in perfect condition.it is missing the ladders and I would like to purchase them.
Company is out of business. Similar fire truck recalled in 2002 for lead paint hazard. See:
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02104.html
Not sure if your model has lead paint. You should have it tested.
Jun 19, 2011 | Gearbox Toys Volunteer Fire Truck #2 Pedal...
Dayton 30' pedestal fan will run for an hour or so, seems to run hot.. there is slight burning smell. then fan makes little noise and shuts down.
Whats happening is that your fan is overheating (usually due to a loss of lubrication in the bearings), and the motor's thermal cutoff is kicking in (due to overtemperature), and shutting down the motor.
This thermal cutoff circuit is installed in consumer motors to prevent fires.
You have two solutions:
(1) disassemble your nice 30" pedestal fan (I've done this a few times - any handy guy/gal can do it),
and lubricate (with automotive bearing grease ($3 at any auto parts store), or 3-in-1 oil for those spots that won't take bearing grease) the bearings, and
reassemble. Re-lubricate on a regular schedule to prevent recurrence.
(2) buy a new one. Give your old fan to the kid on the block who thinks he/she can fix anything &
tell him/her it just needs to be lubricated.
May 13, 2011 | Dayton (2C373) Fan
CAR IS MISSING AND DRINKING GAS LIKE CRAZY
if check engine light is on. take it to an auto parts store and they will read the problem code for free. auto-zone etc, no sense in spending money if you do not have too for the wrong part. have a good day !
Mar 21, 2011 | 1986 Ford Thunderbird
Feb 18, 2009 | 1996 Saab 900
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
