I formatted my USB but than I cannot record, the message on screen stays it's says in order to record a timer the tv was switch to record service
3 Suggested Answers
SOURCE: I have a Soniq L42V11A,
Does it read from the Hard drive you have plugged in? I havent tried recording but I will after reading your post. It read fine from an NTFS formatted Hard drive I'd assume you need to format it either to that or FAT32 (limited to 4gb File size) using your computer.
Posted on Oct 04, 2011
spr1949
  • 1182 Answers
SOURCE: Anyone setup Timer recording on Vivo 32" TV model LEDTV32FHDF
Please read the guidelines given in the operation manual, and follow each step by step. You might be skipping one or more of them and that is why you are not able to set up the timer.
Posted on Aug 02, 2012
Recording from toshiba smart tv onto usb memory stick
How to set up USB Recording
Once you have purchased a USB hard drive and connected it to the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  1. Connect the USB HDD to a free USB port on the back of the TV.
  2. The USB hard drive now needs to be formatted (all data will be deleted).
  3. Most TVs help you to format the USB HDD automatically but on some models, you need to enter the menu and select format HDD (or something similar).
  4. Use your remote to record, play, pause, etc.
Hope this helps.
Feb 09, 2018 | Toshiba Computers & Internet
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
My DVR receiver is recording programs that i originally did not put on the schedule. My receiver is also showing the programs in the guide and my daily schedule as "No Info Available". I have...
Hello! For these issues, here are a few simple steps:
First, for the DVR recording shows, you just need to delete those timers. They may have accidentally been set up.
1. Menu, 7-Daily Schedule
2. Timers
3. Edit list
4. Select any timers that you did not create, or want deleted. This will stop them from recording!
For the program guide:
You just need to download the program guide. Here's a couple easy ways:
First way:
1. Pull up the Guide
2. Press 999 then the right arrow button (Browse) until the guide prompts a download,
Second way:
1. Pull up a menu. Press 6 (Sys setup) -1(Installation) - 1( Point dish)
2. Highlight and select Check Switch on the upper right
3. Select test at the bottom left. (If a message comes up between steps 2 and 3, select yes. )
4. Press VIew live tv, and allow the Acquiring signal message and the guide download to go through.
I hope these steps help!!!
Becki Barned
DISH Network Customer Service
Jan 13, 2011 | DISH Network DISH-2800 DTV Receiver
My Sanyo LCD 40XR10F TV does not recongnise any mp4 movies i have on my external hardrive or usb stick?? Does it matter what size usb disk/drive/how many files are stored on them for it to play them?
Before you loaded the hard drive, and USB did you run a "Check File System" through the TV? These devices in order to use the "Time Shift Function", have to have pass with "SUCCESS", displayed on the screen. If not the TV will format a 4GB FAT32 filing system for you. The reason your MP4's might not work might be due to a firmware update that no longer supports MP4. You should have been OK if you recorded the material from the TV. Items you record from the TV will not play on any other device. Using the FAT32 format only allows 4GB but, the TV allow 8GB and a external device can be FAT32 format to 8GB. 8GB is only 2 hours of viewing time. So that should give you some idea how little the amount of files can be handled.
Dec 21, 2010 | Sanyo Televison & Video
I was wondering if you could help us with our DVD recorder. Its a Toshiba DVD Recorder Model: D-R18DTKB and up until recently has been in good working order. A while back I bought some Sony+RW...
Hi Tony
Although I am a member of this site I came across your post while searching Google for answers to the same issues as you are having.
From what you say and what I have tried I can only put fault with the DVD recorder itself and probably the LASER.
This thing just seems to hate reading recorded media of almost any format including those which it's stickered front panel boasts about. It also doesn't leave you with many other options as there is no USB port either.
I dont use the unit to record or the Freeview facility and never have as we have Sky+ and no TV ariel.
I bought it for the varied formats of video it says it can play but out of 6 different formats that I recorded onto DVD with my PC (and I am an advanced user and work in I.T) it only played back one and badly which was a mpeg-1.
I put the same 6 disks into my sons (apparantly DVD only) player bought from ASDA for £15 and it played 4 of them perfectly as good as the originals!
Logically this would suggest this model is a Lemon. I just hope your not a £130 light lemon as I am!
Oct 27, 2010 | Televison & Video
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
AFTER 6 HRS RECORDING MESSAGE DISPLAYS NO MORE SPACE LEFT
It is true that the manual says it can record 100 or more hours...but that is at the lowest resolution. You can go to the menu screen and from there go to the recording properties and play around with different recording resolutions that best fit your recording needs. Also, the DVR uses a Hard Drive just as any computer does and within' time it becomes fragmented... that may cause it to record less hours even if you delete recordings. You can format the internal hard drive by going to the main menu screen and press and hold (for about 10 seconds) the OPEN and PLAY buttons on the unit (not the remote). At this time you should see the words FORMAT on the LCD screen and the unit will shut off. Keep in mind that formatting will erase everything on the hard drive so make sure you back up to DVD whatever you want to keep. Hope this helps.
Jun 23, 2008 | RCA DRC8030N
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
