Can we connnect this with the normal socket for power?
    Top Expert:
  • Computers & ... Master
  • 8,213 Answers
Connect what to a power socket you have not said what it is...please put all info back on fixya so someone can try and help you with this.
Posted on Dec 09, 2016
I have a lumina harpo v class stand up Sunbed, 8 tubes in one section have gone out at same time.....what could this be? A fuse? Help
There is normally a connector where the secton connnects to power at the top of the stand up, that is probably lose or burnt
Jun 13, 2016 | Health & Beauty
Ok how do you connnect it i know how but do you go to sound setting because i was playing online and turned it on and talked and no one answered
Ok how do you connnect it i know how but do you Problem with the Emerson EM227 Bluetooth Headset ok how do you connnect it i know how but do you go to sound setting because i was playing online and turned it on and talked and no one
Feb 12, 2011 | Emerson EM227 Bluetooth Headset
I have a Toshiba W528 VCR and am trying to hook up a Wii in the front panel Line 2 jacks. How do you switch the connnection to the Line 2 jacks without a remote?
With the up and down channel selector buttons. You will have to keep pressing either button till it shows AV (something IE 1 or 2 etc). Depending what it says on the front panel for the socket.
Recommend a universal remote if you can't get a new one.
Feb 06, 2011 | Toshiba W522 VHS VCR
Not getting connnected via data cable.
Since you have not mentioned anything about your phone condition , i assume that your phone is working normally. In this case your data cable is damaged.Replace the same to new one & try connecting to PC.
Feb 25, 2010 | Nokia 5130 Cellular Phone
Connecting a Toshiba lcd tv to a Sony Vaio VGC-LA3
you should have a (vga) tv-out socket usually blue with about 16 pins in it,if you have not which is unusual then refer to sony for the laptops specs and location of tv-out socket.
The Nvidia graphics card should have one I believe the Gforce go card is the one for your system unless upgraded and is advertised to support this function.
Jan 14, 2009 | Computers & Internet
Left brake light works but the right does not.
reversing the plug connnection is far fetched for the plug would have a guide that will fit into the other socket. If this is not in proper position it wont go in. What type of bulb housing do you have? is it the plastic base type? If it is check and see that the ground connection is not insulated at the terminal. There is a certain plastic coating that develops upon prolonged usage of the lamp assembly itself and is normal, only have to clean out the coated terminal to have a bare metal contact. Did you check the bulb socket of the right brake lamp itself? Heat can cause the terminals plastic surface in the socket to be deformed . Check on this also.
Oct 27, 2008 | 1992 Honda Accord
Network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
Oven light
Yes loose connnection or the socket is no good. Or you have some faulty light bulbs.
Jun 21, 2008 | New World 60ECHDGm Electric Kitchen Range
Compaq C740TU speaker does not deactivates if external speakers are connetced
The internal speakers should automatically be disconnected by inserting a 3.5mm jack plug in the audio out socket. It may be that your headphones or external speakers are using a 2.5mm jack which is too small to operate the switches in the audio out socket. Purchase a 3.5mm jack plug [cheap] and plug this in if it disconnects the laptops internal speakers then you need to connect accesories with the correct size plug.
Mar 14, 2008 | Compaq Presario 700US Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
