there is a thermostat fitted to the electrical wires, this will be the problem, you can sometimes fix them buy putting the copper connection back to its original place, over time and short term use the bent and get stuck, it's like over heating. to stop this you make sure you don't have the thermostat set to low setting, were by its on for a few minutes then off again.
Amazon.com, Inc.
Rating: 3.7 - 29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f4
Possibly the heating element is enclosed by chalc buildup. The heat is still built up, but isolated from the washing water by chalc. Loopup methods to clean the washer or ask a professional.
DON'T KNOW WHAT TO TELL YOU, EXCEPT THAT I AGREE THAT THE BEARING IS MOST LIKELY THE CULPRIT, BEARINGS SHOULD NOT BE MADE OF PLASTIC AS HEAT CAUSED BY FRICTION WILL DEFORM IF NOT MELT IT.
