The ribbon is not advancing when typing
The ribbon stays in place and it keeps typing in the same spot on the ribbon
    Top Expert:
  • Office Equip... Master
  • 8,213 Answers
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
Ribbon will not advance, so keeps typing in same place.
I've uploaded a pdf with the instructions that came with my typewriter to install the ribbons at YouSendIt.com. The link is good until November 29, 2011. If you'd rather I upload this elsewhere (Flickr or something), drop a note here and I'll see it.
http://www.yousendit.com/download/T2dlb2VESEJubHdpR01UQw
Good luck, I hope this works!
Nov 22, 2011 | Olympia Office Equipment & Supplies
Ribbon does not advance but wheel does turn when
You are in the overstrike ribbon mode. Code and Period, comma, or slash will get you out of that mode.
DickyO
Jul 26, 2010 | Olympia Mastertype 3 Typewriter
Ribbon does not advance?
You may be in the overstrike ribbon mode try CODE period or slash should turn it off.
DickyO
May 12, 2010 | Nakajima Office Equipment & Supplies
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Feb 17, 2010 | Royal Office Equipment & Supplies
The ribbon is not moving for each new letter being typed. Its very slow so when you are typing a word it just keeps going over the same spot on the ribbon.
I'll try thisagain use the code key with one of these 3 keys ,.
. , or / this will take you out of the uverstrike ribbon mode.
DickyO
Mar 09, 2009 | Nakajima AE-800 Typewriter
Ribbon not advancing on Selectric II typewriter
on the left far side of the ribbon there is a white vertical post. the ribbon should be on the left side of that. also make sure you turn the ribbon the direction of the arrow (on the cassete) otherwise will need professional repair
Nov 18, 2008 | Office Equipment & Supplies
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
Corona 100 typing ribbon
Either a jammed ribbon or feed gears. Try another ribbon or get it serviced.
Jun 14, 2008 | Smith Corona Wordsmith 100 Typewriter
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
144 people viewed this question
k24674
jasbo
jasbo
