Question about Garden
Hi,I have a 158cc briggs and Stratton victor mow model 10T602.Can I change the shaft seal from underneath the mower?.Or do I need to pull the motor apart. Thanks.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 242 Answers
Drain the oil, tip it over and remove the blade and adapter and key stock if it is not part of the adapter. I drill a few small holes in the old seal and install some wood screws in them, using a claw hammer or flat bar I pry the old seal out. , make sure all is clean. I use a short section of PVC drain pipe to slide over the crankshaft to drive the new seal into place.
Posted on Dec 13, 2016
I have snapped the shaft on my Briggs & Stratton
What shaft, where? Quote your engine number/model/type because there are exploded view parts lists all over the web. Then you could work out if its possible and worthwhile financially.
Oct 09, 2014 | Garden
Briggs & stratton 500 series 158cc. Mowed all lawns, and worked just fine. Then (because it was such a jungle in my yard) I accidentally hit a decent sized piece of cement, but mower worked still after...
When you got it running immediately after the hit on the cement was it running normally? Similar power to before, or a bit rough?
Briggs & Stratton put an aluminium key between the flywheel and the crankshaft, so if you hit something big and stop the engine instantly it doesn't shear the shaft, just the key.
If it's only partially shorn it could still run, but with the timing a few degrees out.
The oil leak is most likely from tipping the motor forward.
The oil gets past the valves and pours into the combustion chamber.
We were told in the small engine workshop to never tilt a B&S side valve motor any way up than cylinder head up (that's the front, or spark plug side on this machine), or carburettor side up.
You'll need to either check/replace the key yourself if you have the skills to remove the flywheel, then you'll need to take out the spark plug (probably oiled up) and clean out the cylinder with some petrol / ether or similar, while pulling the pull start, before replacing the plug with a new one.
May 23, 2014 | Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
How to drain oil from briggs & stratton 5.00 158cc engine
underneath the deck there is a plug, sit mower on bricks/wood and pull plug and use a bucket to catch old oil. Tim
May 22, 2011 | Garden
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Apr 03, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
