West pointe infrared heater wi-0035 making funny noise while running. Sounds like a low growl. What can I check?
MicrowaveSvc
  • 9098 Answers
SOURCE: Sensor Error, Funny Smell and Noise
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Posted on Sep 06, 2008
mrgrzz
  • 88 Answers
SOURCE: Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Posted on Jan 20, 2009
dr_greg
  • 192 Answers
SOURCE: honda heater makes loud noise
ok well its possible there may be something stuck in the blower motor under the passenger side dash. ..or the blower motor itself could be on its way out, sometimes leaves or sticks from trees and even stove inside the glove box can find their way into the windshield cowling and into your blower motor..u can remove it to check by unplugging its white connector and remove the 8mm bolts that secure it into the heater core box..its very easy to remove..the 8mm bolts / screws should also have a phillips head on them...
Posted on Apr 17, 2009
  • 120 Answers
SOURCE: front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Posted on Jun 08, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Posted on Jun 11, 2009
When started, dishwasher making growling (hungry stomach) noise before filling with water
That would be your pump priming, however I would check the sump or filter in the bottom sometimes they get debris caught in them. Some have a filter others have a screen.
Jan 07, 2015 | Dishwashers
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
Front end growling
check the wheel bearings for condition and adjustment
Jan 30, 2014 | 2002 Toyota Sequoia
Grinder makes a scraping sound
They all make a funny growling noise while they're running. It's just a rough fit in the gearing.
Jan 25, 2014 | Dewalt D28110R Heavy-Duty 4-1/2" 115mm...
West point infrared heater makes a loud buzzing sound when truned on
What does this have to do with PC laptops ??? Please post in correct category.
Dec 18, 2013 | Computers & Internet
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
I replaced the rear tire & chain slider on my 2002 triumph america & now i have a growl type vibration from 20-30 mph. all other speeds and the bike runs smooth. chain & rear wheel appear to be...
did you get the wheel and tire Dynamically balanced at the bike shop, if not , Do, check tire pressure , yes its possible and it might make a noise if installed backwards.
new tires make funny noises , but sounds like balance issue
Jun 13, 2012 | 2002 Triumph Bonneville America
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
