Question about Winter Sports
Snowmobile seized problems
So i look at the the oil and it not empty then i look at the antifreeze its not empty ether but once i put a little oil on the pistons and i churn the crank shaft and the pistons pop free and i go to start it runs but the a few min later it dies why is this
2 Suggested Answers
mccluskey1
  • 8374 Answers
SOURCE: I have a Polaris Indy 500 the motor is seized
this forum might help you out... How do fix an engine that seized because of no oil
Posted on Dec 09, 2016
Testimonial: "that give me a up side to what could have happened but see i feel that my snowmobile never ran completely out of oil i believe that it was getting some but not enough to keep it really lubricated i say that because a some of the times i never used oil to get unstuck and i don't think that my engine served any to little damage because when it was running it was running good and strong and then it seized again after i was riding it for a good 10 min and it was never smoking the engine so i don't think it was over heating nor did the over heating light come on."
Oil leak on left side of snowmobile. Riding at 50 mph and all of the sudden oil was spilling on left side. snowmobile still ran. what is leak?
Nytro- Oil leaking When on it's side [Archive] - SnoWest ...
www.snowest.com/forum/archive/index.php/t-44412.html
Dec 13, 2007 - 12 posts - ‎9 authors
Edit: When on it's left side and the oil is warm, i would say I lost about a quart in 30 minutes, just doesn't seem right to me. I will try to find where ... RMK 900 Oil Leak...
Nov 28, 2011
Something is leaking....from where?
Jul 19, 2011
roll over a four stroke?
Mar 16, 2011
oil leak
1 post
Jan 15, 2010
More results from www.snowest.com
Oil leak/ Bone Headed Move? ' TY4stroke '' Snowmobile Forum ...
www.ty4stroke.com > ... > Forums > 4 Stroke Forum > RS General Talk
Apr 6, 2014 - 12 posts - ‎6 authors
If you put the sled on its left side, you probably would have oil leak out an overflow tube, as oil would probably get into the airbox, and leak into ... Possible oil leak RS GT ' TY4stroke '' Snowmobile ...
Feb 28, 2015
Oil Leak ' TY4stroke '' Snowmobile Forum '' Yamaha ...
Dec 7, 2014
CRAZY OIL LEAK ' TY4stroke '' Snowmobile Forum ...
Feb 15, 2014
Oil leaking......help??? - TY4stroke '' Snowmobile ...
Jan 22, 2012
More results from www.ty4stroke.com
I have an oil leak - HCS Snowmobile Forums
www.hardcoresledder.com > ... > ZR/ZL forum
Jan 25, 2016 | Cars & Trucks
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-344777.html
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/...snowmobiles/5470-pull-start-not-workin...
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from www.snowmobileforum.com
Jan 04, 2016 | Garden
Why won't my 1998 Polaris indy 500 start? It is getting fuel and has spark.
Along with fuel and spark...you need enough spark and you need enough compression. Asssuming your rings aren't broken and you can feel good compression when you are turning it over, you can spray a little ether in the carburetor chamber. If there is enough spark and compression it will at least fire up momentarily.
Sometimes the rings or cylinders get scratched up because they run incorrect gas/oil ratios for too long and then when they sit for a while the oxidation fills in those scratched surfaces. Starting with high fuel to oil ratios is easier to start ( gas burns easier with less oil in it) but the engine will wear faster with high ratios.
But if the engine won't start under pure ether, then the spark is real weak or out of time, and/or the compression is shot. Good compression makes heat and concentrates the air and fuel together. If the compression even falls from 10:1 to 8:1, that is enough to cool the charge from about 150F down to about 90F or so and you won't get ignition
Feb 23, 2015 | Winter Sports
Had water freeze up in my car engine and radiator. flushed it all out and added antifreeze but my car still wont start
that is not what the problem is , are you getting gas , ck the fuel pressure at the fuel rail should be at 40 to 50 lbs or something like that , could have a frozen fuel line put some gas in it ,try a little ether and fi it starts with that then you fuel pump may be bad
Jan 10, 2015 | Cars & Trucks
How to troubleshooting
take the plugs out and retry to spin it.. does anything shoot out of the spark plug holes??antifreeze.. oil...may have seized or blown engine..
Dec 27, 2013 | Cars & Trucks
Have 2000 excursion with water in the oil
take to mechanic ,blown gasket or cracked blockor casting,major problem don't drive, will damage motor or seize up! water jacket in engine could be compromized
Jan 24, 2013 | 2004 Ford Excursion
Kia sedona emmits white smoke with brownish oil dripping at the exhaust .is it from head gasket or someparts in the engine?
head gasket yes, bc antifreeze is entering throught the oil ports or down throught the rings, if the water get to the oil it will wipe your bearing out
Jan 08, 2013 | Cars & Trucks
Im always having to put antifreeze in once a week. The way i know it needs it is when temp. gauge surges all the way up then it comes back down. No visible sign on any leaks any where. When i drive to...
Take a close inspection to your waterpump. Pump has a "weep" hole in bottom side of casting. It's an early warning system to detect seal leak before waterpump seizes up and does major damage. It could be so slight that coolant is blowing back along oil pan. That would be where I'd start. Do you smell coolant inside the rig? If so, check passenger floor up to firewall for dampness in carpet - indicating heater core leak.
Mar 06, 2011 | 1996 GMC Jimmy
Oil in the antifreeze and hardly any heat.
what you need is called a head gasket job.thats why you have no heat your oil and antifreeze are mixing making your car smoke,and will overheat causing serious engine problems dont drive it like this you will seize motor
Jan 29, 2010 | Ford Windstar Cars & Trucks
Winter Sports Logo
116 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
