Question about Samsung Televison & Video
I Replace Y-Buffer Board on 50 samsung Plasma TV cause i have Horizontal line going my tv when i replace the y board got but has sound but no picture can you help me
    Top Expert:
  • Samsung Master
  • 77,947 Answers
Have you done the flashlight test to see if the image is present but not lit up?
Posted on Dec 09, 2016
How to fix Black Horizontal Line on Samsung Plasma TV (PN60F8500)
It is possible that the buffer board will fix your problem, but try removing, cleaning and reseating the flex cables between the buffers and the panel first. All it takes is a little bit of dirt or oxidation to open a connection and cause a line-out condition. Use a lint free cloth and a little bit of alcohol to clean them. Make sure to fully insert the cables and center them perfectly in the connectors or you will have even more lines. If the original line is still there after cleaning, then try replacing the board. Buy a board from a reputable dealer that will guarantee no problems with the board. If you still have the line even after changing the board, then the plasma panel has failed and the only fix is to replace the panel.
Always let the tv set for an hour unplugged before attempting any repair work. There are dangerously high voltages in plasma tvs that can cause severe shocks or even *****.
Feb 07, 2017 | Samsung PN60F8500 60" 8500 Series Full HD...
Black horizontal lines on screen on my p50h401a plasma tv after replacing upper buffer board
Hello, the problem is with the buffer board ribbon cable. You have to really force them in there till you see no more lines, then close the latches in place "try using both hands" and press into the board HARD :)
Jan 16, 2014 | Hitachi P50H401 50 in. Plasma HDTV
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
HI,i was whacthing the tv and on top the screen did appear 6-8 horizontal lines,i did try to turn on/off,......i need help.thankyou.
Normally this is an overheating issue or a power supply issue. For the overheating issue, take a vacuum and some compressed air and blow out the back of the TV. Dust can collect and cause components to retain heat that will cause the TV to produce horizontal lines called artifacts. Sometimes these are permanent but sometimes they can be repaired before replacement.
Mar 01, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Hi - we've just got a brand new Samsung c450 42" plasma. Its been okay for about 5 days, but tonight approximately 7 or 8 white and coloured lines have appeared vertically on the right side of the screen....
If it's a new TV take it back! There is a problem with either the PDP or the Y Buffer board. If it's still under warranty, call Samsung and have them fix it.
If not, are the lines pink? If they are clustered in 1 or more strips (usually about 3 in apiece), the Y Buffers are starting to go bad. Do not watch the TV - it may cause more damage and blow the YSUS board if this is the case! Replace the affected Y Buffer, and the lines will go away. I had to replace the upper buffer in my Samsung HPR4272X/XAA (my [3] strips were horizontal, and on the upper half of the TV).
If its the Panel, there is not much you can do about it (at least in my experience) except replace the panel. At that point in time, it's more cost effective to get a new TV.
Sep 27, 2010 | Samsung Televison & Video
Screen problem with my LG 50" Plasma TV
its the buffer driver board the big long board that plugs into your tv,, i have one for sale if u need one,,30£
this will cause the lines on your tv after replacing the ysus it could well be that ysus mabe faulty still if u replace buffer and find u still have the lines 9/10 times when the ysus goes it normally takes out the buffer board on these worst cases the control board,, but im 98% shure its buffer board.. let me know on here if u find out.
Apr 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a Samsung Plasma TV (PN50A450) with sound but no picture.
Y board, Y-buffer board, or panel can cause this problem. Anyways, replace the panel shall be good, because those boards will come with the panel.
Apr 21, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
