Question about Westinghouse Televison & Video
My westinghouse w3223 tv screen is black when turned on and I have no sound, I replaced the backlight inverter, still same symptoms, how can I fix it?
    Top Expert:
  • Westinghouse Master
  • 75,417 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 10, 2016
I have a 52" westinghouse
Ok you have a lot of things going on here. Your first thing with the lines can be your T-con board or your Signal board or the screen itself. The second thing black screen you would have to be more specific? Is your back light on and you have no image? If that's teh case then I would replace the T-con board or the Signal board. If by black screen you mean there is no light on the screen from the backlight inverter then your BAcklight inverter or the backlight itleft might be bad. and ontop of that you might have the problem that we started with also. You can get westinghouse parts from www.interliquidparts.com You have to order by part numbers so you have to get the number from the actual part of your TV.
Jun 13, 2011 | Televison & Video
My Westinghouse SK-32H540S pictures shuts off after 10 seconds. the sound stays on but no picture. is it the troubleshoot? i tried unpluging everything and repluging it and still the same thing happens...
This problems are the tv 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards provide the tv LCD screen pannel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Tv comes on then the screen goes black but can still here sound
This has to do with the voltages supplied to the backlight inverter. There with be 2-3 capacitors needed for the 24v rail which is NEEDED for the backlight inverter to work. Without the backlight inverter you will have no picture and still have sound.
If you are good with electronics you can open the set and replace those capacitors and your 24v rail will be restored. You will then have a picture and sound
Please rate if this was helpful!
Mar 03, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My westinghouse flat screen tv - i turn power on picture comes on for a few seconds and goes black - sound still works - any suggestions?
The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Oct 07, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
We have Westinghouse LCD TV model number is LTV-32w1 and the problem is that screen is black though we hear the sound of the channels of our Direct TV service. Does it mean that it is broken or still may...
Ur tv have a dead electronic's board known as a LCD inverter backlight board.Replaced this LCD inverter backlight board,u will get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long in shape board.
Mar 09, 2010 | Televison & Video
My LCD HDTV screen keeps going black.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
