Question about Hobart Food Mixers
What is an err code 11 on hobart legacy HL800
Age of mixer Serial # 11-064-362 A-200
Id contact Hobart. the serial # doesnt use a date code. Hobart Contact Us
Sep 02, 2015 | Hobart Food Mixers
Pushing the start button, a code of 6_9d appears. What is the issue and how can I fix this?
It's telling you that the bowl guard is open. If the bowl guard is in place and closed then you could have a bad bowl guard switch.
Check www.hobartservice.com for your local Hobart office.
Aug 21, 2011 | Hobart HL600 Legacy Stand Mixer
Power went out then back on and mixer reads err and 12 in the timer turned breaker off then back on still reads err
Leave the breaker off for at least one minute then try it. If that doesn't take care of it then you will need to have Hobart come out and check the frequency inverter (drive).
May 21, 2011 | Hobart HL600 Legacy Stand Mixer
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
80 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
