Need igniter switch for patio heater G-PH018PPS
    Top Expert:
  • Heating & Co... Master
  • 75,822 Answers
Contact the maker of the heater, we do not sell parts or have any way to look them up here at fixya.com
Posted on Dec 09, 2016
    Top Expert:
  • 12,104 Answers
Go online or an appliance store
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
Patio heater phs won't ignite
Hi, First check if you have a full tank and that the pipes are clear of any insects, water or debris. Next see if you have a spark where the pilot is, if you can hear the piezo clicking but cannot see a spark then check the lead. Sometimes the lead can get loose and short out lower down and prevent the spark from reaching the pilot. You may need to take the lead out to fully check. If you have a spark and gas is reaching the pilot then check the tilt switch, if faulty it can turn the gas valve off. To check you can just short out the tilt switch, found this site very useful patio heater problem solving.
Oct 01, 2011 | Endless Summer 2009 Open Flame Patio...
Where do i get a book or assembly instructions also need igniter
Uniflame Patio heaters are manufactured my Blue Rhino. You can find what you need at the following link. http://www.uniflame.com/BRWEB/getdoc/74bac003-eaff-41fe-9d7c-7b02c79b6c3b/Outdoor-Heaters.aspx
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Uniflame 200209 Open Flame Patio Heater
Pilot light wont ignite on patio heater
It may be that your cylinder is malfunctioning, cylinder has a leak, or the pilot is clogged. Please see steps below to troubleshoot. Note:Regular maintenance is critical to the successful operation of your patio heater.
  1. Is the cylinder valve closed? If so, open the cylinder valve but not fully.
  2. Check to see if you can light it manually. If the unit lights manually but not with igniter, service or replace igniter switch.
  3. Ensure that there is no air in the gas line. Open the gas line and bleed it (pressing control knob in) for not more than 1 - 2 minutes or until you smell gas.
  4. There may be a blockage in the orifice or pilot tube? Bugs and spiders get into the pilot assembly, venturi tube and burner ports causing the unit to either not light or poor performance.
  5. Is the regulator hose pinched or kinked?
  6. Cleaning the pilot assembly.
  7. If the piezo igniter won't spark to light the pilot, check the wiring to the igniter, It may simply have lost it's ground. Slide the wire off the igniter prong (looks like a thick needle) on the pilot assembly and then push it back on. That usually will reestablish the ground.
If you continue to have problems with the heater, contact Blue Rhino (the manufacturer) Customer Care 800-762-1142.
Hope this helps you to troubleshoot and solve the problem. Please let me know.
Apr 21, 2011 | Uniflame 200209 Open Flame Patio Heater
Pilot on my patio heater will not stay lit. goes out when i release the knob
If the heater is the same as this type of patio heater and it lights on pilot and goes out it is generally a worn thermocouple. These are designed to switch off the patio heater when something is wrong, changing one fixed 90% of the problems. Sometimes it can also be caused by a worn tilt switch but always start with the most likley and work backwards. Found this site very useful, patio heater problem solving page.
Jan 04, 2011 | Stainless Garden Sun Steel Propane Patio...
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
