Question about Seiki Lc-32b56 32 LCD HDTV
Hi I have a Seiki tv model LC-32B56, the volume started turn off and on but itself and now seems to not work at all , any suggestions?
    Top Expert:
  • Seiki Master
  • 75,157 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on Dec 10, 2016
SOURCE: Sharp Aquos LC-26D4U sound problem
Well, apparently this is a huge problem with many flat screen TV's. They surpress the volume output from all external sources (like DVD players) so you don't blow up their tiny speakers. They just expect you to add on a home theatre system to boost the volume their small speakers cannot handle. This is a real problem if you are in a boat or RV and do no have the space or electrical capacity to do this. I had the TV checked out and Sharpe said it met their factory standards so there was no help there. We have had to go with a small amp & speakers just to hear the TV & DVD movies etc. They need to put better quality speakers in these TVs. The video is awesome, now work on the audio guys!
Posted on Oct 20, 2008
2smart4u
  • 73 Answers
SOURCE: volume not loud enough
are you watching movies frm a dvd player with the sound up, if so, turn the sound up on the dvd player remote and see hwo that works. eor, if its movies on normal tv screen, go to settings and click booster sound too hear better. if yours does not have this, ring your manufacture for a refunded tv with better speakr sound quality.
Posted on Oct 25, 2008
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Posted on Aug 17, 2009
AJIN G
  • 6694 Answers
SOURCE: Sharp LC-60LE810UN. the sound all
hi,
You have to check three things.
1. Check is the mute function is ON or not. For that press the mute button on the remote.
2. Check the speakers of you tv. For that you have to open the tv. For testing the speaker you need a multimeter. Check the coil continuity of the speaks. it should be 4 ohms or 8 ohms. If there is no continuity then change the speaker with a new one. If the continuity is ok then
3. You have to check the audio output amplifier IC ( integrated circuit). For finding out the audio amplifier ic which one it is, just follow the wire from the speakers. Its other end will ends in the socket near the audio output IC. It will be fitted on a aluminum heat sink (radiator)
To replace the IC you need soldering ion,desoldering pump, solder etc.
the part number will be written on it. you have to purchase the same part with the same part number.
ok
Posted on Apr 27, 2011
No picture and no sound but got a little red light at come on tv
Hi Cindy,
The power supply needs to be checked and repaired in your set. Please consult some local Tech.
Good luck
Jun 30, 2015 | Seiki Lc-32b56 32 LCD HDTV
Volume don't work to tv
In the menu for audio, there will be a selection for TV speakers on or off. They are probably switched off.
Dec 07, 2014 | Seiki Lc-32b56 32 LCD HDTV
My seiki tv turns on but no picture freezes at logo
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Sep 01, 2014 | Seiki Lc-32b56 32 LCD HDTV
Need the factory restore settings so i can restore my lcd television because i enter the wrong model # of updates and firmware to my lcd model:LC-32B56 television
To make it a factory reset, you have to enter its service mode option. There is no external reset button or so to this set. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Entering service mode, and do adjustments procedures to many brand TVs are given.
Dec 25, 2013 | Seiki 32"LCD...
Need remote codes for sky with Seiki tv
028,022,025. Try these codes.For more information check this link.Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Dec 09, 2013 | Seiki Lc-32b56 32 LCD HDTV
Seiki lc-32b56 tv will not power on at all. It just stopped working. No red light, no nothing.
Turn the wall switch back on...if it still won't work, check the breakers on the side of your house.
Jul 31, 2013 | Televison & Video
Need verizon remote control tv code for Seiki 32B56 TV
0205 code worked for me. 32'' Seiki TV with Verizon Fios remote.
Jan 16, 2011 | Televison & Video
Seiki Lc-32b56 32 LCD HDTV Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
