Question about Cell Phones
Our screen has gone blank just got a spanner and clock on screen
How do you reset the Inspect indicator with the service spanner on the dashboard of a 2007 Polo Classic 1.9 TDi
Hi,if the spanner comes up and there is a beeping sound,try turning the ignition off then push the button in thats near the spanner clock,hold it for a cupple of seconds then still holding it down turn it from left to right and let go,turn the ignition back on and hopefully its gone,if not try again just in case you made a mistake.
hope this works for you,all the best.
Aug 08, 2016 | Cars & Trucks
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
Which direction doe the locking nut turn and in the absence of spanner wrench what could be used in it's place
It turns anti clock wise and you can use a box spanner or a socket set or adjustable spanner. Do not use anything other than correct toos to avoid injury and damage to the locking nut and thread.
Nov 14, 2009 | Kenmore 24032\24036 Top Load Washer
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Mazda 3 (2006) Information Display panel is blank
I took it to the dealer. They fixed under waranty. The new issue is the flash and beep confirmation upon double locking the doors no longer works.
Apr 15, 2009 | 2004 Mazda 3
Digital clock visible image no longer shows, just blank!
look on the fuse panel on fuse panel cover inside ther is a list and diagram of fuses. Check corresponding fuse if it is not blown then you need to replace a bulb.
Nov 13, 2008 | 2003 Toyota Corolla
The screen on my motorolla k1m has gone blank
KRZR's are JUNK...The wire in the hinge has a problem, I've gone through 4 in under a year
Aug 03, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Blank Inside Screen
The LCD needs to be replaced on the phone, so take the phone to a mobile service center and have it replaced
Jul 19, 2008 | Samsung SCH-u740 Cellular Phone
Radio and clock
change new clock
May 26, 2008 | 2006 Suzuki Swift
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
