April Air 560: water is pouring out of the unit casing, along the seam,not into the tube. Water pad is not even wet. I think the water flow is somehow missing the pad and collecting in the housing.
I have cleaned out everything, reassembled carefully with the water incoming seems to be getting to the black tray above the water pad. I changed the pad, noting it appears to never having been wet. So I think the water incoming is somehow diverting enough that the black tray and water pad aren't getting wet, and the water collects in the housing.
    New Friend:
  • 14 Answers
Feel water pipe from soap dispenser could be blocked with soap it will feel solid clear with a length of wire carefully so as not to puncture hose flush with hot water to remove remaining soap
Posted on Dec 10, 2016
My kenmore elite series a/c a120t leaks from the bottom even with a drain tube.
I assume you mean it's leaking out the front. If that's the case and the drain tube is working, the rear of the unit may not be tilted down enough. The rule of thumb is 1/4" to 1/2" downward tilt on the rear. This allows the water to flow to the back of the drip pan faster. Also, be sure that the air intake filter is clean and not wet.
Hope this helps you and thnks for choosing FixYa.
Aug 07, 2011 | Heating & Cooling
Master cool not cooling. Outside air is dry and temp between 100 and 108. Fan working, water pump working. Water pan is full. Water flowing to top of padPad gets wet but only lightly. Air from cooler...
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Jun 28, 2011 | Heating & Cooling
Just had my pad and pump replaced (12-inch pad) and now cooling is drastically reduced. The company said they installed a much higher capacity water pump usually used on large commercial units. Can too...
You may want to check to see if in fact the pads are wet. Sometimes the build up in the service tube along the top may be clogged not allowing the water to flow or perhaps the float is adjusted to low not allowing the pump to operate correctly. Once the pads are soaked it should cool nicely.
Jun 20, 2011 | Mastercool 67471 Evaporative Cooler Air...
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
Aprilaire 560 problem. Water isn't flowing into humidifier. I replaced the copper line to the solenoid and it still doesn't work. When I turn on the manual thermostat I hear a click but no water flow. I...
Have you tried activating unit when connection on discharge side of solenoid is loose to see if you are getting water flow thru solenoid. If not then you need to clean or replace solenoid. Thanks.
Nov 22, 2010 | Heating & Cooling
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
Water pours out the tube from the lennox humidifier
A small discharge of water coming out of the bottom of an April Aire drain spud is normal. This feature constantly tries to rinse the system. This helps to prevent the possibility of mold or bacteria accumulating in the unit from standing water. It may appear to be alot of water. But be reassured that you are breathing in cleaner air. Now if it continues to drain constantly even when it is turned off then you should repair the unit.
Apr 04, 2009 | Aprilaire 550 Humidifier
Floor on passenger side gets wet when running air conditioner
I have a 2006 Fusion with the same issue and I fixed it for less than $2. There is a drain tube that goes from the passenger floor board out through the firewall to allow water to drain under the vehicle. However, water can travel along the underside and seep back into the vehicle. I went to a hardware store and bought a few inches of 5/8" tubing. I simply slipped this onto the drain and the water now flows down the tube and safely away from the interior of the car. Been dry ever since.
Jun 03, 2008 | 2004 Ford Taurus
Washing Machines Logo
Top Washing Machines Experts
