Question about Health & Beauty
My scale only reads 0.00 - Health & Beauty
My scale reads full when i turn it on whats wrong
Most scales will have what is called the "TARE" button... push the "TARE" button when nothing is on the scale and it should 'zero-out.'
Once it is zeroed, it should give honest weight readings.
May 13, 2016 | Health & Beauty
How do I switch the comma to a decimal so it reads 0.00 instead of 0,00
To switch the radix mark between the US and European modes, press the yellow shift key then the ./, key on the bottom row of the keyboard between the 0 and = keys.
Jan 22, 2011 | HP 10b Calculator
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
When the calculator is turned on, the display reads 0,00 and then in the below right side there is a letter C. How do I clear this?
If the C indicator is displayed it reminds you that interests are compound interests. It it does not show, interests calculated are simple.
To toggle between compound and simple interests, press the key sequence [STO][EEX].
Dec 15, 2009 | HP 12c Calculator
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Display Problem & Question
To remove the comma, turn off the calculator. With it turned off, push and hold down the [ON] key. While still depressing the [ON] key, push and hold down the decimal or [.] key. Now you should have them both held down. Now, release ONLY the [ON] key.
To remove the "c", push then release the [STO] key. Then push and release the [EEX] key.
Nov 19, 2007 | HP 12c Calculator
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
