Question about GE Toaster Ovens
How do you tighten handle on door of GE toaster oven mdl 168989
  • yadayada
    yadayada Dec 09, 2016
    Post a picture of the problem please.
SOURCE: Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Posted on Sep 12, 2008
SOURCE: Toaster oven door
Try They do thousands of parts for white goods.
Posted on Dec 03, 2008
SOURCE: toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Posted on Mar 31, 2009
SOURCE: Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Posted on Mar 14, 2010
  • 1772 Answers
SOURCE: The handle came off the
Sorry to read about your problem, I hope this helps you out.
get goop glue from home depot
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
Replace door handle
Not enough info to help you. However, if the door can be separated into two pieces fitted together, you will see the screws holding the handle.
Otherwise, you have not asked a question.
Oct 20, 2013 | Calphalon HE650CO XL 1400 Watts Toaster...
Need to tighten screws holding handle. How do I do this?
We were able to tighten them down. We:
unscrewed the handle entirely;
removed the little black rubber/plastic screw covers (you won't be able to use these with this fix);
held the handle stationary in one hand;
used needle-nosed pliers to turn the screw into the handle;
then switched out the pliers for some small tweezers as the handle got close to the dooor, and turned the screw with the tweezers.
Note that the left-hand side of the handle is reverse threaded. So, you will turn the screw clockwise to screw in on the left; and counter-clockwise to screw in on the right.
Aug 03, 2011 | DeLonghi RO2058 Toaster Oven with...
What is the electrical rating of the Convection Toaster Oven Mdl #169127/169140 as the manual states that the extension cord should be at least as great as the electrical rating of the appliance. I will be...
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
Jun 17, 2011 | GE 168947 Toaster Oven with Convection...
How do i order a door handle for an convection toaster oven?
Go to parts and type in the make and model number. They have parts for whatever you need. If not there, try Hope this helps
Jan 22, 2011 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Do you still need top elements or do you still have your GE 169104 oven?
Apr 16, 2010 | GE 168947 Toaster Oven with Convection...
Door won't close
Lose hinge? Tighten it with a plyer.
Apr 02, 2010 | Krups FBC412 1600 Watts Toaster Oven with...
Kenmore toaster oven handle fell off
try magic putty. it works on everything
Jul 11, 2008 | Toaster Ovens
Toaster Ovens Logo
245 people viewed this question
Top GE Toaster Ovens Experts
Mack Baxter
Michael Teter
Michael Teter
Level 1 Expert
stanley austin
stanley austin
Level 1 Expert
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
