Question about Furniture
Wine enthusiast 274 02 40 not cooling correctly with beeping every minute or so.
Wine cooler keeps beeping every other minute with temps flashing, inside lights flashing and temps going from Fahrenheit to Centigrade.
  • 833 Answers
SOURCE: Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Posted on Dec 21, 2007
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 286 Answers
SOURCE: U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Posted on May 18, 2009
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
I have a wine enthusiast Model 2720206 and I don't know how to set the temp?
The answer is partly incorrect. This type unit DOES NOT USE freon as it is thermoelectric utilizing a heat pump. Unfortunately, part of the answer is correct. It likely will cost about $100 to "ring the door bell".
Sep 19, 2013 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
The bottom section of my wine enthusiasts model 272 03 24 dual temp wine cooler is "dead".
These units cool using the same technology as your PC. There is a heat sink (aluminum block with fins) that has a fan that exhausts the heat out of the Peltier cooling module. Go to you tube and search as it looks very similar to this: http://youtu.be/JqCLdT2k0dc Take the fan off the aluminum fins and vacuum and/or use compressed air in a can. Amazing how much dust you will find. Reassemble and you should see a difference. Good luck.
Sep 08, 2013 | Wine Enthusiast Refrigerators
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
I have a "the wine enthusiast" wine cooler and it's a 2001 model 2720216, 16 bottle storage, and it is not cooling the temperature stays at 80 degrees can it be fix or just get rid of it and buy a new one?
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Aug 23, 2010 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Nov 02, 2009 | Refrigerators
Furniture Logo
205 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
