Question about Sharp AR-M237 Copier
How do you reset the local admin pin?
At one time I knew how to reset the local admin pin on the printer but I can't seem to remember. Does anyone know what the process is - I kinda remember using the c*# a time or two. Reason being is that somehow it's been changed on one of ours and I need to do a local config for DHCP - it's not wanting to take through the Web Interface.
  • 143 Answers
#/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON
67-17 will clear the printer settings.
try "0 0 0 0 " for the admin. code
Posted on Aug 01, 2009
Cant remember the password
Push a pin into the reset hole at the back of the router for about 10 seconds.
Now the default username is (admin) and the default password is (admin).
If that wont work then leave the password field blank, and only enter (admin) as the username. Remember no brackets.
Jun 25, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Hi i dont know where is the pin number in my linsys wrt54g v5 router,thanks
If you mean the wifi pin you will need to log in to the router to find it. This is fairly simple and goes as follows. Enter 192.168.1.1 into the address bar of your browserd_schrute.png
The default username and password are: (blank username) password:admin (lower case)
Click on the 'wireless' tab at the top of the web admin page
Click on the 'wireless security' sub-tab
the pin should be displayed.
Aug 20, 2011 | Linksys Wireless-G WRT54G Router
Can't remember my password to my router and I' m trying to use my new lab top
There is a pin sized hole in the back of it. You can press the button in for 10 seconds to reset the router.
Default username and password is usually
admin
admin
or
admin
password
Nov 10, 2010 | NetGear WGR614 54Mbps Wireless Router...
D-link dir-628. I can't remember my user password. I need to
the only way I know to go about changing a password after its been established on the admin account is to restore the modem or router to its factory defaults using the reset button usually about the size of a pin on the rear of its case
Hope this helps
Be sure to leave feedback
thanx
Robb
Apr 02, 2010 | D-Link DIR-625 (790069292637) Wireless...
Cannot remember pass code from base. just added wireless and it asked for pass code
If you did not remember you password you just reset your router and use (admin) for the username and password. To reset your router you can see a small hole in your router that labeled reset. Just insert a small pin and push.
Apr 01, 2010 | Belkin (F5D8231-4) Wireless Router...
I forgot password for my window on my mini hp 110...how do i reset password and take it by to factory defult
I knew your password problem. For I have met the similar problem with my HP Windows 7 laptop admin login. As I remembered, then I just go to Google Search "Forgot Windows 7 Password", and get tool "Windows Password Recovery" from search results!
Hope my experience help you!
Feb 23, 2010 | HP Pavilion 110-1030NR Notebook
I cannot find the ADMIN PIN for a new LEXMARK T654. Is there anyway to reset it?
The only way to gain access when the admin pin has been lost is to open the panel on the left side of the printer. With the printer off, rRemove the metal cover over the board. Look for a small yellow jumper. There should be a series of three pins with the jumper connecting the center and right pin. Move it to the left so it covers the left and center pin. Wait about a minute and then turn on the printer. You should be able to regain access to the menus. You may always want to do a restore to factory by holding in select (checkmark) and right arrow then turning on the printer and releasing the buttons after about ten seconds to gain access to the service menu. From in there you can reset the printer back to factory. You can also reset just the network to clear a forgotten web password for example. These instructions also work on the Dell equivalent which is a 5530dn I believe.
Feb 08, 2010 | Lexmark T654DN MONO LASER PRINTER
I'm trying to reset my lynksys router but can't get past the initial login. Don't know my old user name and password. Admin default doesn't work. States access unathorized
lower case admin is the password.Reset the router ,use a paper clip or a pin reset button between the ports hold the button down for twenty seconds.
try 192.168.1.1 in the address bar in Internet Explorer.When the log on appears type admin in lower case and hit enter you should be in the you can set up the router again.Remember to save settings on each page and copy the network key and store it in a safe place for future use.
Good luck
Nov 19, 2009 | Zyxel Prestige 334 Router
Cannot remember my username and password
try user:admin or user:admin password:admin or just password: admin ...no username or...there is a reset button the back of the router where the cables go, its a pin sized hole. grab a paper clip and stick it in there and press and hold the button for about 5-10 seconds...all the lights on the front will flash and it will reset to defaults
then try the above user names
Apr 26, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Sharp AR-M237 Copier Logo
351 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
