Question about Panasonic KX-TG9541B Dect_6.0 2-Line Bluetooth Cellular Convergence Solution Landline Telephone
Where is the hold button on the KX-TG9541 handset?
VM access
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voice mail access code and press [SAVE].
Apr 22, 2014 | Panasonic KX-TG4753B DECT 6.0 Plus...
Voicemail
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Got instruction to unregister KX-TG6074B
    If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
    1) On the base unit:
    Press: FUNCTION or PROGRAM
    Button name varies by phone model.
    2) Press: MUTE
    3) Enter the numbers 3, 3, 5, #
    4) Enter the handset number (1 to 8)
    Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
    Phone issues.
    1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
    If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
    Mar 14, 2008 | Panasonic KX-TG5633B Phone
    Panasonic kx-tg1100
    STEP1:
    On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
    This will discard the registration of the handset to any base.
    STEP2:
    Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
    NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
    After you finish all the above, hold down the "PAGE" button for about 5 secs.
    You are now done!!!
    Good luck
    Simos
    Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
    DeRegistering a Damaged Cordless Phone???!!!!
    I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
    Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
    Panasonic KX-TG9541B Dect_6.0 2-Line Bluetooth Cellular Convergence Solution Landline Telephone Logo
    270 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
