Question about Dishwashers
No lights are on on control panel. Circuit breakers are on, but nothing is happening.
catriver
  • 878 Answers
SOURCE: Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Posted on Nov 05, 2006
  • 131 Answers
SOURCE: no lights on the control panel
check the thermal fuse at the control panel, the door switch, or the electronic control.
Posted on Mar 10, 2008
  • 89 Answers
SOURCE: frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Posted on Oct 28, 2008
localwonder
  • 6784 Answers
SOURCE: No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 13, 2009
  • 16 Answers
SOURCE: we have Frigidaire 24 in. FDB1050REC dishwasher.
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Posted on Jan 16, 2010
I have a Sauter oven. When I try tuning it on nothing happens. No light,no fan,no heat.The clock display seems OK.I tried pressing the menu button several times.Nothing helps.What can be the solution?
I should suspect the fuse or circuit breaker that is supposed to power the oven if turned off.
It could be nothing more than a power surge from a lightning strike somewhere.
Find the electric box and check it out.
If the fuse or circuit breakers panel is good, remove the oven and check for current at the wiring that goes from the oven to the fuse/circuit breaker box.
If all that tests good, you have a problem with the oven control.
It may be "toasted". (No good)
God bless your efforts.
Sep 08, 2016 | Ovens
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
Kenmore 11087577260 After lightning storm inside light works,but nothing on the control pannel will work
I've had that happen before. The lightning blows out an electronic component on a circuit boart for the panel of if lucky maybe a fuse or breaker.
Try to look at a manual on sears webpage.
Jun 26, 2011 | Kenmore Dryers
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
Jun 23, 2010 | Kitchen Ranges
Good Morning. The downstairs lights are not working.I checked the fuse box[Hager]and the fuse swich was off for the lights,i flicked this back on thinking lights would come back on [apart from supposed...
I assume you mean circuit breaker when you say fuse. If you reset the breaker to "on" and the lights still don't work, look for a GFI outlet somewhere in the circuit. It could be tripped which will shut off the current downstream from it if it is set up to guard the downstream circuit.
May 26, 2010 | Electrical Supplies
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
I just finished cleaning my swimming pool and tried to switch on the water pump but nothing happened.Then i noticed that the red trip light on the control panel was on. What do i have to do to fix this?
hi! there,
open the control panel,besure to close circuit breaker first,on control panel there is a over load protection relay,push the reset lever,then close the control panel,switch on the breaker and push the black push button to start the pump,observed if trip off again,check the cathridge filter,replace filter because the differential pressure
was exceeded the set up on pressure switch.have a nice day,don't forget to rate me,thank's
Apr 23, 2009 | Home
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
