Question about Hardware & Accessories
My moms timer 052-8808-8 does not have pegs it has buttons that push down . How do I set it?
3 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Posted on Jun 12, 2008
SOURCE: I am assumimg that when
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Posted on Sep 30, 2010
I need game rules for 1978 Milton Bradley "Knock Out" game
So. I played this game years ago, and just pulled it out of my moms closet of games. Anyway, its similar to Othello, if you've ever played that. Start with putting pegs into the inner circle/hexagon, with every other peg facing opposite directions. Then the first player puts one of his/her pegs into the game, trapping their opponent's peg between theirs, and then pushing out the trapped peg and replacing it with their own. Once the board is full, the player with most pegs in it, wins. You can only push out pegs that are between the one you play and existing pegs from previous play.
Dec 12, 2014 | Milton Bradley Toys
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Setting times:
Sep 29, 2010 | Hardware & Accessories
Black Peg on timer
We just used to use a sliver of bamboo, just make a piece and sand it down, bit by bit, until it is a Tight fit in the hole you want about 5mm to protrude, through the bottom, that is what "Trips" the "Contacts" inside. So anything similar will work too. Just remember whatever you use, has to protrude a little bit inside the face of the Dial. & be strong enough, not to break when pushing the Contact.
Mar 28, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
LOST THE SETTING INSTRUCTIONS OF MY TIMEX MODEL NO. 12/874 (TX12874X)
I couldn't find a manual for your Timex, but here are the setting instructions:
Clear the timer by pushing hour and minute at same time. To set current time, hold time button down and push hour. Then hold time button down and push minute.
To set the time for light to turn on, hold the ON button down and push hour until it gets to the hour you want it on (same for Minute). To set time for light to go off, hold the OFF button down while you set the hour and minute.
Nov 30, 2009 | Timex Hardware & Accessories
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Hardware & Accessories Logo
41 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
