Question about Food Processors
I have a 14 cup processor i bpught recently. It worked to chop nuts. Then emptied bowl refilled and now wont turn on. Everything in place and locked
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: My brand new Cuisinart 14
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
SOURCE: Grinding nuts
Try chopping the nuts first and remove them. Prepare the rest of the dish and add the nuts, mixing them in at the last.
Posted on May 28, 2009
  • 12 Answers
SOURCE: GE 14-cup digital food processor;
how old is your processor? did you buy an additional warranty when you purchased it? If so you should read the paperwork. Whats covered,and not, should be listed. you can probably buy a replacement bowl for it on the website.
Posted on May 11, 2011
How much is a blade (not the disc the other thing) for this product (Hamilton Beach Big Mouth 70590 14 Cups Food Processor)?
Replacement parts for the Hamilton Beach Big Mouth 70590 14 Cups Food Processor can be ordered online from this supplier:
http://www.abtecparts.com/proctor_silex_fp_70590.htm
The chopping blade is listed at $12.99 USD but depending on your model you made also need to order a replacement bowl for $9.99 USD.
Thank you for using FixYa!
Aug 24, 2011 | Hamilton Beach Big Mouth 70590 Food...
GE 14-cup digital food processor; bowl cracked, either by lid fastening or ice cubes in the bowl while chopping mode; don't know exactly. Is this covered by warranty ? Or are separate bowls available...
May 11, 2011 | GE Food Processors
My kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Put in nuts and turned to mush
It is extremely difficult to chop walnuts in a food processor, because they turn to powder within a few seconds. I have chopped them using both a Cuisinart food processor and a Moulinex La Machine. The difficulty arises because even after you have released the on or chop button, the blade continues to spin for a second or two. The Cuisinart DLC-8S is not particularly well-suited for chopping nuts, because the blade is not reversible - there are many Cuisinarts that do have reversible blades - a particularly good one is the Cuisinart DLC-2A, which has both a reversible blade and a Chop function (retails for about $29.99 to 39.99 nowadays).
The only way to have any success whatsoever with the DLC-8S is to press the pulse button and release immediately - only use a small amount of walntus - and then dump the bowl and add a few more at a time.
Apr 04, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Grinding nuts
Mar 18, 2009 | Hamilton Beach 70450 Food Processor
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Food Processors Logo
50 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
