Water is running out of the spin button when I turn the machine on.
    New Friend:
  • 14 Answers
Soap dispenser blocked remove and clean check pipe to drum clear
Posted on Dec 10, 2016
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My washer is not working it begins to spin stops and has the letters LE appearing.
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
May 27, 2008 | LG Washing Machines
LE CODE ON MACHINE AFTER FILLING WITH WATER, ROTATE A COUPLE OF TIMES THEN TRY TO SPIN BUT COULDN' T
If this is an LG front loader, this is a solution from LG that worked for me 2 years ago, and has been well-rated on Fixya:
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
If yours isn't an LG, please post an update with model information so helpful people can give more specific assistance.
Oct 22, 2010 | Washing Machines
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Water fills in and out during the whole cycle but no spin
unplug the machine for 60 sec or more then plug back in this may help this resets the computer good luck
Dec 17, 2007 | Malber P21 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
