Question about Samsung Televison & Video
My Samsung UN55F6350AF TV has dim horizontal areas across the screen at the top and middle
  • 39 Answers
SOURCE: Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Posted on Feb 20, 2009
  • 75 Answers
SOURCE: TV: bright line across black screen for several hours.
vertical problem need to check for bad solder joints on vertical ic would be helpfull if we had the model number o f yur set. also could be bad capasistors in vertical section.
Posted on Mar 09, 2009
boltthedog
  • 24 Answers
SOURCE: my samsung plasma has horizontal line across middle of picture
loose wire check connections
Posted on Sep 19, 2009
johnnydiode
  • 647 Answers
SOURCE: only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 28, 2009
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
Horizontal lines in Samsung led tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 18, 2017 | Samsung Televison & Video
How to fix horizontal lines appearing on my Samsung TV
its a screen fault
if lucky and you can get one
one of the electronic boards inside the TV needs replacing
Mar 07, 2017 | Samsung Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Tv is dim through the middle
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 13, 2015 | Vizio E-Series E420i-A1 42" LED TV...
I have a Samsung 50 inch 3D Plasma TV (model number PN50C7000YF) that has recently started developing black horizontal lines across the top of the screen all in a 3 inch horizontal area. Every week I get...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Samsung PN50C7000YFXZA PN50C7000 3D Plasma...
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
White Horizontal line across screen
It is most likely the vertical deflection IC has overheated and lost its soldering. If you open your TV up, it is a 10-15 pin in a row IC sticking out of the motherboard attached to a heatsink. It should be labeled "IC451." Give it a wiggle, see if it affects the picture, You may have to resolder them in place.
The IC may be hard to find, look for a peice of metal that is sticking out of the motherboard, attached to a small chip. I fixed a samsung tv that had it in the middle area.
Mar 27, 2008 | Zenith Z32H41D TV
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
