Question about Honeywell Heating & Cooling
Where can I find the reset button on a Honeywell HZ-709 heater.
My heater tipped over this morning (it was not on)and when I went to turn it on it will not work. After reading the other posts on this page I have tipped it over a couple more time, given it a good shake, unplugged from the wall and waited 10 minutes but none of those have worked. Is there a reset button anywhere on it?
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
SOURCE: I just opened the box
http://www.kaz.com/kaz/store/product/4b7bfb893c912601a6b76fdd700d5329/
Posted on Jan 25, 2009
  • 408 Answers
SOURCE: how do you set heater to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Posted on Feb 20, 2010
  • 408 Answers
SOURCE: We purchased the Honeywell HZ-709 heater and the
That is the manual that you need. Hope this helps. If you need anything else, let me know.
  • 43 Answers
SOURCE: My honeywell hz 709 heater
Hello, Usually unplugging the unit and letting tho oil settle for about an hour will reset the unit. Hope this works for you. Please reply and let me know , so if need be I may assist you further. Thank You!
Posted on Feb 14, 2011
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
My honeywell hz 709 heater tipped over slightly and now it will not come on. How do I fix this?
Feb 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Heater was knocked over. now will not come on
try tipping unit over to reset the safety switch that was activated when it fell. u may have to do this a few times.
Jan 05, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Heater will not work
chelk the mains cord,chelk the voltage in the heaters element if no then chelk the heat aduster(thermostate) if current is available on element then your element is burnt replace it.
Jan 08, 2010 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
