Question about Dometic Refrigerators
I have a Dometic RM2801 frig that, even on the lowest setting, freezes items in the frig box. The thermocouple looks like the end is dicintigrating, could this be the problem?
    Top Expert:
  • Dometic Master
  • 7,919 Answers
Thermocouple check for cobwebs in tubes and check sensor inside fridge
Posted on Aug 30, 2017
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
HVACRH20
  • 237 Answers
SOURCE: Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Posted on Jan 18, 2007
jumptrout51
  • 3361 Answers
SOURCE: Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Posted on Mar 21, 2009
SOURCE: Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Posted on Apr 14, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Posted on Jun 17, 2009
I can't get a regular temperature in my old brown Danby Inglis frig . It is freezing every item in the frig even at the lowest ajustement. Can you help me?
Most likely temperature control thermostat needs replacing. Also check damper between fridge and freezer. If mechanical, adjust where less air is going in fridge section. If not mechanical, but electric, damper door may not be closing.
Sep 23, 2017 | Danby Refrigerators
Dometic RM2801 gas works but electric does not. Checked 110v outlet works fine.
The RM2801 uses a manual thermostat. So it sounds like you have a bad heating element. It is located inside of the duct work on the right hand side of the rear of the fridge. First disconect the two wires that are attached to it from the other end. Then you should be able to remove it through the access door in the duct work itself. It just pulls straight out from the top. ArctiCold Refrigeration We keep it cold 5fc81d9c-d5c1-46de-a664-d4bcc0595561.jpg
Sep 03, 2013 | Dometic Refrigerators
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
Everything in frig frozen solid, even when set on lowest setting
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 14, 2011 | Frigidaire Refrigerators
Even at lowest setting refrigerator side freezes up
Possible failure of the thermostat or the sensor to the thermostat that is not working to control the cooling temperature and hence making the compressor work.
Try and set the thermostat to lowest just a little before it cuts off , if this wont work then the thermostat is faulty. Check the wires of the sensor to the cooling coils.
Mar 13, 2011 | Dometic NDR 1292 Refrigerator
I have a Dometic RV frige that freezes everything in the frige section even when i have it set on the lowest temp setting
thanks for the question sounds like a defective cold control replace it thanks the appliance doc
Sep 16, 2008 | Refrigerators
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
75 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
