Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
In sink erator is leaking from bottom
In sink erator is leaking from power cord connection at bottom
  • 65 Answers
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Posted on Jul 22, 2009
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Badger .5 1/2 in sink erator garbsge disposal leaks from bottom
Replace disposal, motor and electrical connections are getting wet
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 03, 2014 | Garbage Disposals
Why does my in-sink-erator hot water dispenser is dripping from the bottom
Ck connections on top. Will run down and come out of bottom. If connections are water tight tank is bad , replace.
Apr 27, 2014 | Washing Machines
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leak from area where cord comes out of the in sink erator
Not good seal could be bad are you sure it is not leaking from the top and running down the side.Fill sink all the way then pull plug get a flashlight and examine well.
Apr 17, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My sink erator badger 5 is leaking at the bottom, should I replace it or try and stop the the leaking.
mine was leaking from bottom, dripping off power cord...pulled it apart..the pan that separates the water and food from the electric motor was developing pin holes from corrosion...I dont know that you can get this part...was thinking about tacking a small weld...but best off getting a new one...I am sure it has served...
Jan 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have an in-sink-erator model 1-81 which is leaking from the power cord attachment area and from a small rectangular metal piece mounted on the bottom of the unit. Replace or repair and is this possible?
The unit's seals have failed. The metal piece covers the box where the cord is wired to the motor, meaning the motor above it is already soaked with nasty water. It's definitely your best value replace the disposer. If you get another insinkerator or one made by insinkerator (whirlpool, kenmore, etc) you can hook up the new one in three easy steps.
Feb 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher water at bottom of well.
That little plate has to be gently removed with a screw driver and a hammer.
Apr 01, 2009 | Dishwashers
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
4,640 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
