Question about Dishwashers
Dishwasher doesn't turn off. Pump keeps turning on and off at regular intervals. Program buttons are not working. Is this repairable or needing a new programme panel?
textonor
  • 130 Answers
SOURCE: drain pump won't stop
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
Posted on May 11, 2008
vitg55
  • 70 Answers
SOURCE: kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Posted on Dec 08, 2008
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
  • 3 Answers
SOURCE: hobart dishwasher lxic detergent pump will not run
Is the pump shaft turning during the wash cycle? If so I bet it is the same problem I had with my sanitizer pump on my 24" LXIc. remove the pump cover plate & replace the internal tube. Search this site for hobart LXIc sanitizer problem.
Posted on Jul 09, 2009
SOURCE: neff dishwasher s5433xogb/29 pump keeps running
Our Neff Dishwasher S5456X0 the pump was running all the time and the solution 1 worked. We removed the front panel under the door and the the flood camber was full of water. Drained it out with a sponge and the dishwasher is fine. Thanks
Posted on Dec 13, 2009
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Dishwasher keeps coming on and then turing off during all cycles, what could it be
I am slightly unclear about the problem.
What do you mean by coming on and turning off during all cycles.
Does the dishwasher turn itself on even when it is turned off?
If coming on means the drain pump starts as soon as you select a program cycle then most likely the flood switch is activated which causes the pump to start to make sure there is no water left inside the dishwasher. You will have to find the location of the flood switch and dry it out. make sure power is turned off when you are working on the dishwasher components.
If this solves the problem there you also need to find out what is the source of the water leak.
Mar 17, 2011 | Asko 24 in. D3350 Dishwasher
What is involved in a 150000 mile service
If you have owned the vehicle for some time and have kept up with regular service intervals you only need to do minor work... oil change, transfer case fluid change, front end lube and check everything over. Often though along the way, service intervals become blurred by individual repairs. (example: if your water pump was replaced, the coolant was likewise changed therefore at the next service requiring coolant replacement it's too early to do that) Considering that, or, if you are a new owner, it's wise to give yourself a new "baseline" by replacing ALL the fluids (including power steering and brake fluid), ignition wires, cap, rotor, plugs, carefully inspecting belts and hoses etc.
After doing that, you can reliably follow the routine schedule, keeping notes on what was done and when.
Nov 27, 2010 | 1993 Jeep Grand Cherokee
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I cannot figure out how to advance a cycle without having to go through the entire cycle. For example, I had a drain problem with my sink and the plumber put the rinse and hold cycle on for about 10...
Welcome to FixYa.
Your post doesn`t specify a model number, however on most Bosch dishwashers in order to change from "rinse & hold" to "regular" ( or any cycle ) simply turn the unit "on" and once the machine begins push the regular button twice.
Or the button applicable to the cycle you want.
That should change the display to look like this...
If this doesn`t work, try it for "econo" or any alternative and let me know how it goes.
Good luck.
Regards,
Macmarkus :)
Sep 03, 2010 | Bosch Dishwashers
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
To Enable or Disable the Cycle Completion Signal...
1. Open the door, hold down the “Quick Wash”
button and simultaneously turn the Dishwasher on.
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it
doesn’t beep, it means that the Cycle
Completion Signal has been disabled.
3. Turn the Dishwasher off to take it out of
program mode.
I hope this answer's your question. Thank you for choosing "fixya".
Please rate the solution favorably if indeed it was helpful, if not please let me know.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
