Question about Maytag Dryers
Maytag maxima dryer the is locked and wont release
2 Suggested Answers
SOURCE: my maytag neptune washer model
there is no "red string" on this specific model. Its really irritating that everyone is saying this when clearly no one can find a red string. Stop giving this advice. From what i can tell so far the release lever is inside the machine and to get to it you have to remove the front panel. My problem now is i cant get the top electronic panel off to get the front panel off... this machine is like a giant chinese handcuff!! I will never buy a maytag ever again!!
Posted on Aug 18, 2010
I have a Maytag Maxima XL dryer and I need to turn off the control lock
press and hold the control lock button/selector for @3 seconds it should turn off. this step is used to active or diactivate the control lock feature. refer to you owners manual
Apr 23, 2017 | Maytag Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Maytag Neptune door won't lock, or start the was cycle.
check all wiring for tightness and any corrosion from door latch up to the central control unit first,if ok then replace door latch component as this part wears out quickly you will need to remove washer top,then door boot spring to release door boot from door frame to access wiring to door lock component
May 06, 2012 | Maytag MDE5500AYW Electric Dryer
Button ongear shift on nissan maxima wont move out of park
Hi Glen, Make sure you foot is pressed firmly on the brake pedal while pushing the release lever. Wiggle the lever from side to side at the same time as that may help release the lock. If that fails, look a plastic cover close to the front of the consul. Lever that open carefully with a screw driver and press the lever inside it. That should release the lock. Make sure no substance has been spilled inside , as that will result in the safety lock sticking. If there is anything clean it up and lubricate with WD40. Regards Johngee10
Oct 05, 2011 | 1996 Nissan Maxima
My washer just shut down mid cycle and is locked. Lights wont come on and it wont turn on to even get the clothes out. What can I do?
You can remove the front lower panel and reach up the left side and you will feel a little tab hanging under the door switch . Pull this and the door will release.
Nov 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My 1996 maxima key wont open my trunk and neither will the trunk release button
the trunk release button has a little metal like a hammer that hits the trunk lock to release if bent will not open or if you disable it by pushing it down to disable trunk release button the key lock is frozen will not work even if key go's in normal. need to replace it. if u need to get in your trunk and if it is empty would be easy to do just open the middle part of the back seat panel and with a thin and sturdy stick and flash light can hit the little hammer to open it . hope it helps
Aug 03, 2010 | 1996 Nissan Maxima
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
