Question about Teac Audio Players & Recorders
Has the teac cr h255 a fuse? The apparatus doen't respond at all safe for an unnatural click when connected to power
Looking for spare remote control,or universal remote that would be suitable.
go to e-bay and search for remote for teac cr-h255
you will probably get new ones or 2nd hand units
Jul 22, 2015 | Teac Audio Players & Recorders
My Teac AG-V3020 makes clicking relay sound when attempting to power up.
recheck your connections it appears that something is cross if so recorrect the connections on your system
Nov 29, 2014 | Teac Audio Players & Recorders
Teac cr h255
I think it is a problem related to overheating of the cpu. Question is whether your cpu fan is running. or is it running fast enough, say within 1000rpm. It will go faster if the workload is more. And while installing the cpu did you put some cooling jell/pest right on the back side of the processor. If none of these are applicable I will suggest that that you should contact someone professional asap.
Apr 03, 2014 | Acer Computers & Internet
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Sep 23, 2010 | Teac Audio Players & Recorders
How do i connect TEAC CR H225 and iPod
I think all you have to do it use the while usb to ipod conector to conect the ipod, from the looks of a picture of the teac it has USB input, failing that read the user manual or technical details off the internet, that the first thing i would do.
Mar 21, 2010 | Audio Players & Recorders
My Teac A-H300 amp has lost all power
Could be a fuse, or a connection from the power supply to the circuit board. Where is this installed? Has it taken any abuse? If it just sits idle and doesn't move, it could be a fuse, and it could be a circuit board. The biggest problem is it's TEAC...haha, just kidding.
May 09, 2009 | Teac A-H300 Amplifier
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
29 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
