Question about Sewing Machines
Tension on upper thread not right, thread keeps snapping
  • Sewing Machines Master
  • 12,278 Answers
Most likely, your tension is too tight. First thing, unthread the machine. RAISE the presser foot and rethread from the beginning. The standard initial tension setting is the midway point between high & low number, HOWEVER, that will probably need to be tweaked as machines vary.
The tension is correct when upper and bobbin threads meet in the middle of the fabric. If the thread continues to break, then there may be a snag somewhere that is catching the thread and breaking it. Also, check that the thread notch on the spool is not catching the thread. Be sure your needle is compatible with the thread, ie the thread is too thick for the needle eye.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Posted on Dec 09, 2016
Why does top thread keep breaking?
Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
Jun 18, 2017 | Sewing Machines
Upper thread keeps breaking
The most common cause of upper thread breakage is incorrect threading. Remove all the thread, install a brand new needle, RAISE the presser foot, and then rethread from the beginning. (Verify with the owner's manual that the threading process is correct.) The other thing to check is the upper tension setting. The factory standard setting is usually the halfway point between the high and low numbers. Tweak the upper tension to achieve correct tension. Correct tension is when the upper thread and bobbin thread meet in the middle of the fabric. The upper tension is meant to be the most common method of tweaking tension. As such, a sewist should become comfortable with tweaking the upper tension.
Jan 19, 2016 | Sewing Machines
I can't get the tension right. The stitches on the top side are too loose and the thread just pulls out.
loosen the needle thread tension of a bit
sew on a scrap bit of material until you get the tensions right
correct tension is when the bottom thread and the top thread meet at the join of the two pieces being sewn
you will only need to sew 1" to see how it is going
Nov 22, 2015 | Sewing Machines
I have a singer advance and the thread from the top starts out sewing correctly but within a short time becomes too tight and snaps what is the problem
Try to go for a regular maintenance. Here i have added a video which will help you to carry out the maintenance process. Hope after that you problem will be solved.
SINGER Sewing Machine Maintenance Troubleshooting
www.electro-medical.blogspot.com
Oct 06, 2015 | Singer Sewing Machines
The needle thread keeps breaking, I'm using good quality thread and have tried re threading and changing the needle but it still keeps breaking, any advice would be most welcome.
1. Set the tension on the bobbin.
2. When you thread the upper thread do it with the pressure foot up.
While you are threading give slight tugs to check for snags. If there are snugs you must fix them.
3. Put the pressure foot down and adjust the tension to four. Give a tug. It should have tension but still allow the thread to flow.
(Look at your thread and look for fuzz on the sides. This indicates a bad quality thread. A good choice is embroidery.)
4. Make sure the needle has been installed going the right direction. Usually flat to the front or to the right side.
5. Turn the hand wheel while you hold the needle thread to the front.
The bobbin thread should come above the throat plate in about one turn.
NOW YOU SHOULD BE ABLE TO SEW.
LOOK AT INFORMATION ABOUT BOBBIN TENSION.
Jul 23, 2015 | Sewing Machines
My top thread keeps snapping on my consew 118. There are loops on the underside when I stitch with it and the thread keeps snapping at the needle. It is threaded right but it keeps happening literally...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Thread looping on the bottom of your fabric can be caused by little or no top tension or too much bobbin tension. Another cause is thread or lint caught in the top tension.
Make sure the thread is between the tension discs and that no thread or lint is caught
Apr 09, 2013 | Sewing Machines
Bottom thread is loose and loopy, have tried new needle, thread, cleaned out bottom, tension adjusted.....nothing works, can you help. I see many others have same problem but i cannot see an answer
When your bottom thread is loopy it means that the UPPER thread is not properly threaded. First make sure your needle has the flat side to the back of the machine and that it's the right size needle for your machine and the fabric you're using. You probably missed the tension discs when you threaded the upper thread. Make sure that your presser foot is up and that your needle is in the uppermost position. Try re-threading it and when you get to the tension discs pull the thread back and forth so you hear a little snap. That tells you that your thread is being placed in the discs correctly. (This also cleans out your tension discs in case there's lint in them.) Make sure that you tension dial is on about #4. Finish threading and you should be good to go. Thanks for using FixYa!
Aug 26, 2010 | Elna Heirloom Edition 6005
Thread keeps snapping - Brother JS 23
Try adjusting your tension. I had this same problem and then I adjusted the tension of my thread for each project I was sewing and it solved the issue.
Sep 03, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
