Question about PRINTER Office Equipment & Supplies
I want to know a colour printer every parts with image
  • kakima Dec 09, 2016
    Hi snehasis mahapatra, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Any particular printer?
Not printin g all the time & all blue
Without knowing the Model of Printer and any specifics I will try to cover all the bases I can.
If your printer uses a Tri-Colour cartridge and Black Cartridge then it is most likely that either the Magenta in the Tri-Colour cartridge is either Empty or Blocked or the Black cartridge is Empty.
To test this you can take the Tri-Colour and Black Cartridge out of the printer and press the Printhead against a tissue. The Black should be a solid black line approximately a centimeter long by 3 Millimeters wide. The Colour should have three solid lines, one of each colour Cyan, Magenta and Yellow. If either of these is not clear then the cartridge that does not leave clear footprints will either be empty or blocked.
If your HP printer uses seperate ink tanks for each colour then the Printhead may be blocked or the Ink Tanks are empty.
If it is a Laser Printer then there are several possibilities open. The Toner Cartridges are Empty or the Toner Seals have not been removed. If they are still full and the seals are removed then the Imaging Mirrors may be damaged or the Imaging Drum(s) may be damaged.
I hope that helps.
Jul 11, 2011 | HP Office Equipment & Supplies
My Epson is printing fine lines of different colours across and over the images that I am printing, if i am printing black the lines are blue, if in colour the lines are magenta or blue in different parts...
Check out this link for Stylus drivers for your printer. What I have found is that you can always go down with printer model for updating drivers but not up. Just copy and paste into your browser.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14387&prodoid=28907797&infoType=Downloads&platform=All
Let me know if this helps, and if I can help you with anything else.
JimmyC
Oct 02, 2009 | Epson Stylus Photo 1290 InkJet Printer
How do you change the ink from black to color i dont wont it to print black but i dont know how to change it
first go start menu,then click settings click printer and faxes.
second go to you default printer right click printer preferences.then go to
find out ink colour or black you will see on have a sample small image inside when you choice print out with colour or black their image will automatic change for you.
try this because i no sure with brand and model printer you have....
Aug 15, 2009 | Lexmark C533DN InkJet Printer
Hullo I have a c900 aculaser, printing fine and now on all colour images, there is no image just block of colour and a series of broken repetitive lines. Help! Christine Willis tel 01803 866577
Unplug your printer power cable, restart your computer and plug the printer cable back and on it and tryt to print. this may help. thank. let me know if it works
Jul 02, 2009 | Epson AcuLaser C900 Printer
I have a clp-350n samsung colour printer. Prints B+W images fine. When a colour image is sent to the printer the printer runs and runs and runs but never prints anything. It's as if the imaging belt can't...
There is an "opto coupler" in the main drive gear unit (right ride of machine) which controls the drive to the toner/dev units. If this (or part of the drive) is faulty it will give this error.
Jun 17, 2009 | Samsung CLP-315W Laser Color Printer
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
How to align an image runner C3200
The colour alignment is carried out automatically. Run auto gamma adjust. If this does not resolve anything, some part is at fault. Typical faulty item would be slipping transfer belt.
Mar 31, 2009 | Canon imageRUNNER C3220 Color Copier
COLOUR PRINTING
A thermal printer will only print in black because it burns the image into the paper like a hot iron. It produces a black image because of the surface of the paper is coated. Usually the image fades or goes away after six months.
If you hade a label printer that uses color transfer ribbons, that would work if they have other colors available besides black. I don't know if that is an option with this particular model.
Mar 10, 2009 | Dymo LabelWriter 400 Thermal Printer
PRINT COLOUR IMAGE FROM GOOGLE IMAGES
getting vertical lines on my pictures . i have a epson cx5000.
Jun 08, 2008 | Epson Stylus C66 Inkjet Printer
27 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
