Question about Element Televison & Video
How do I check if my element 40" internal speakers are on/off and if it may be set to sound bar only? I didn't see that in the manual anywhere then again the manual doesn't explain much of anything.
    Top Expert:
  • Element Master
  • 40,280 Answers
The initial set up procedure may have an option for turning internal speakers off and on. If set to off, audio output is directed from the rear of the TV to the inputs of the sound bar.
Posted on Dec 09, 2016
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: It will not recognize my sound bar the section for turn off speakers are grey out and it also doesn't see the sound bar.
If the sound bar is missing and speakers are grayed out--if using a box means a setup option there is causing this.
If in set means a similar issue---most likely is a cable box if used is disabling the sets menu for this.
You may if using a box want to disconnect all connections to the set and unplug both set and box to see if after a wait both will reboot when plugged back in.
As a last resort with the model number call Toshiba customer service.
Posted on Apr 01, 2012
SOURCE: Sony BRAVIA KDL-40V2500 audio not working
my sony bravia tv turns on pics fine but i cant get any sound coimg out from the tvtv. i have tried to the setting and everything but still not working!
Posted on Oct 02, 2012
How do I go into my element tv and shut the speakers off so that I can see is the sound bar will work that way
You may be able to turn off internal speakers by returning to the initial set up procedure.
Jan 01, 2017 | Element Televison & Video
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
Dec 27, 2015 | LG Televison & Video
How do i turn off internal speakers to hook up a sound bar?
There may be an internal speaker disable option in the initial set up routine.
Aug 13, 2014 | RCA L32HD31 32 in. LCD HDTV
Sound bar does not work with tv
You are not the only one with this problem!
Try plugging some other speakers into the soundbar and seeing if that works.
If it does, then the problem could be in the TV - its internal speakers may need to be turned off first; and/or check you are connecting with the right socket eg: 'Output'. on the TV. Read the manual!
Mar 05, 2014 | Element Skateboards Element 46" Class...
Internal speakers sound
Check the Audio configurations. From the start menu go to control panel and audio settings and check the out-put devices, as somtimed you need to select the inernal speakers manually if you have previously changed them to an exteral source. Click internal speaker and run the diagnosis. You should be able to hear a beeping sound.
Sep 18, 2013 | Compaq Presario Notebook
I have a samsung lcd tv that I am attempting to hook up a craig sound bar getting no sound out of external speaker
Check the settings on your tv. Many tv's need to have the internal speakers turned off in order for audio to be output from rear jacks.
Dec 31, 2012 | Craig Electronics CHT912 Bluetooth TV...
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Not sound on pc matherboard g33mo2 from dell
There was a problem with the internal speakers with this model.
Firstly, try a pair of external speakers plugged into the sound port, if these work , the issue lies with the internal ones.
If there is no sound through the external speakers, check that you have the sound driver installed, that the volume is set using the FN and F keys and that the sound icon on the desktop bar does not have a x through it indicating it is disabled.
You can download an updated sound driver from the Dell site, although i think Windows 7 comes with its own sound driver for this.
If the problem points to the internal speakers, you have a few choices:
Return the laptop to Dell under warranty (if it is under warranty)
Try to obtain a set of internal speakers and replace these
Takr the laptop to a computer shop and get them to check the internal speakers and repair if necessary
Dec 30, 2010 | Dell Vostro 1510 Laptop
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Televison & Video Logo
50 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
