Question about Vehicle Parts & Accessories
New car remote not working...can't start car...no valet mode instructions on remote...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
First check the battery. A lot of button batteries are cheap and don't store very well so I suggest going out and buying a new one and replacing immediately.
Posted on Dec 09, 2016
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
When I press the starter button, the function light appears and the car doesn't start.
Hi Kih8259! The vehicle might be in "Valet Mode" this does not let the remote start the car. In order to exit Valet mode do the following: Press and release the F button twice and then press the unlock key. Now, try and start it again to see if it worked. Hope this solved the problem!
Feb 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
What is the valet button and what does it do?
Valet mode on remote starts is there so that when you have someone working on your vehicle the start button for your remote start won't work. Say you're getting an oil change and for some reason the button is pressed, the vehicle wont start with the technician under it and no oil in the engine. In your owners manual it will tell you how to turn Valet mode on and also how to turn it off.
Dec 06, 2010 | 5303P LCD 2Way Security System with Remote...
Which one is valet button on the viper 474
No key in ignition, door wide open, press lock-unlock-lock within one second. That will valet the alarm and the led will light up steady. Follow same instructions to remove alarm from valet mode.
Oct 04, 2010 | Viper Security and Remote Start System...
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
Remote start will not work after dealer programmed a new key.
Yes you need to reprogram your immobilizer bypasskit and depend the model you have it is the program mode, I sugest you go under the dash and try to find out the bypasskit box wich is a small black box like 2"x3"in. and see what model you have.
Jan 23, 2010 | Directed Dei Valet 561r Remote...
I have a 561r that was professionally installed and working fine for about a year. Now all of sudden my van will not fire or start the engine. The theft light continues to blink. I cant start the van with...
Try disconnecting the alarm putting in a valet mode and start the vehicle with the car key. If you don’t know how to put in a valet mode, check your alarm manual. After if the car start them the problem is the car alarm, make sure all the doors, trunk, hood are close if still not working check if the hood, trunk switch are working properly.
Jan 01, 2010 | Directed Dei Valet 561r Remote...
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
