Question about Ovens
My ovena akl887/701 element has gone how do i change it
    New Friend:
  • 14 Answers
You should get 18 ohms across an element if its ok swich off cooker remove shelf's normally 4 screws holding on back panel inside oven you can now see element 2 screws hold element in position you may see them inside oven or failing that remove rear panel of oven and undo screws pull off spade connectors refit new element it dose not mater witch way arond the cables go as long as the earth is in the right place if fitted
Posted on Dec 11, 2016
Smeg se280x has just gone dead in middle of cooking .the digets have gone and is blank the oven fan @ light still work but that is it regards paul ?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 18, 2011 | Smeg SE280X Stainless Steel Electric...
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 13, 2011 | Smeg Ovens
Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
NEmmake sure you removed the correct item first
replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Jan 26, 2011 | Whirlpool AKZ159IX Oven
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
How to clean roof of AKL 828 /1x
Buy a can of oven cleaner suitable for use in electric ovens and follow the instructions on the can. Its basically spray the aerosol foram and wait then rinse off or preheat the ovena nd do the same and depends on the brand that you buy. It is a bit smelly but does the job! Most supermarkets and domestic appliance stores stock these products.
Sep 29, 2009 | KitchenAid Architect Series KEBC208KSS...
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Fan oven element
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
Dec 31, 2008 | Ovens
Oven not working - fuse blown
Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
Plz rate this solution.
Thanks
Dec 14, 2008 | Smeg Ovens
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
