I have 2050 machine, its heat roll damage nail by heating, what can I do?
2 Suggested Answers
  • 61 Answers
SOURCE: function clothes will not dry, no heat
Hello, A dryer can have no heat for a few reasons, the first thing to check are the breakers or the fuses in the fuse panel. If one fuse is open the motor will run but there will be no heat. If this is not the problem I need more details (make, model# etc.) Thanks good luck
Posted on Dec 27, 2008
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
How does the roll out safety switch get damages on a raypak 156 pool heat
over heating check gas pressure if ok check to see if needs windstack to keep from rolling out front
Jun 15, 2014 | Raypak 130,000 BTU Propane Gas Pool...
Kyosera km 2050 error code co180 display
Machine number mismatch
Machine number of main and
engine does not match.problem is Data damage of
EEPROM.
Apr 09, 2014 | Kyocera Mita KM-2050 Printer
Heat damage
This is not a good indication. Led screens are especially sensitive to heat. You may have damaged the led panel. If so, it will have to be replaced.
Oct 18, 2013 | Garmin GPS
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
I have a DCS50 - 8 yrs. old. I print glossy label sheets through it (extra-heavyweight) that the tech says are wrecking the heat roll. He has replaced it 5 times this year and now it needs it again (after...
Any Cleaning solutions of any kind not provided by Xerox will damage your "sweet printer", my advice is find a way of getting a good buy on the heat Rolls form Xerox since you have an older model, buy in bulk them press them for a good discount then keep your machine rolling for another 8yrs!! :)
Dec 03, 2010 | Xerox DocuColor 12 Printer
I have an e2 error on a wide format xerox 3001
Check for a jam sensor actuator hanging up. Check for paper dust or toner particals on the sensors if you can see them.
On these types of machines they require lubrication on the fuser mat for proper lubrication to the heat roll and paper transport.
If this mat has not been serviced it might contain high amount of toner on it causing excessive drag on the heat roll. There can be unusual wihistling or bumpy noise when this occurs.
Also the in this case the heat roll might be damaged and may be replaced.
Oct 15, 2009 | Xerox 3001 Copier
10-359
make sure all the connections are in good shape. Look for a broken or slightly burnt connector.
A pinched wire may be the problem.
And the over heat thermistor may have blown.
Its a fuser sensing code. You may have to replace the fuser itself.
Feb 28, 2008 | Xerox DocuColor 12 Printer
22 people viewed this question
k24674
jasbo
jasbo
