Water keeps pushing up out of the spin button.
Mw612 rest code
Was the motor controller or display board replaced.
You need to re-size these to your machine.
SIZE SETTING MODE.
To set the size switch,
turn the power on at the power point and off at the console.
Push and hold the WATER TEMP UP button then press the
POWER button.
To select the size of the machine,
push the temperature up button until the cold LED is on for
5kg machines,
push the water level up button until the low water level LED is on for
the 6kg machines,
push the SPIN SPEED UP button until the hold LED is on for 7kg
machines.
Apr 15, 2014 | Fisher and Paykel Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel button.you should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Jul 29, 2010 | Kenmore HE2 Plus Front Load Washer
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
Fills up when not on
you have a leaky water valve it leaks because one of the solenoids in the valve is stuck open, the unit senses the water in the drum from the leak and therefore must be drained before it can start a new cycle, replace the water valve.
Apr 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Filled with water overnight
Hi When I plug it in is there any light on the panel that will come on without hooking it up the water lines???
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
