Question about Vehicle Parts & Accessories
Red light on prestige 620tx remote stays on after changing battery, drains the remote battery and then remote doesn't work anymore
3 Suggested Answers
  • 75025 Answers
SOURCE: changed battery in remote for
The transmitter incorporates a small LED visible through the case which is used to indicate battery
condition. You will notice a decrease in transmitter range as the battery condition deteriorates.
Transmitter battery replacement is recommended at least every 10 to 12 months, depending upon how
frequently the transmitter is used.
To replace the battery in the APS620TX:
1) Remove the small # 0 Phillips head screw from the rear of the case.
2) Remove the rear cover to access the discharged battery paying attention to the proper polarity
3) Carefully remove and properly dispose of the discharged battery.
4) Insert the new battery, close the case, then reinstall the small case screw removed in step 1.
5) If you accidently dislodge the circuit board from the transmitter housing, be certain that the rubber
membrane is seated properly, and the buttons are properly exposed from the front view of the case,
then insert the circuit board, and return to step #4.
APS620TX Uses GP23 Battery
It is the sole responsibility of the user to operate the vehicle this system is installed in a safe manner.
This device must not be used in an enclosed space like a garage, attached or detached, car port, or any
partially enclosed areas. Also this device must be placed in the service mode when dropping the vehicle
off for service to prevent injury to the service technician
These are the information about the battery replacement to your device. There is no other details given. Check the battery contacts inside the remote for any dirt or rust, which prevents the good contact for batter y terminals. If there is, clean it . OK.
Posted on Oct 20, 2011
  • 4 Answers
SOURCE: When I hit the lock button, on my prestige 620TX remote, remote blinks, car lights blink, doors do not lock. Unlock and auto start work fine.
you need to take it in to the dealership
Posted on Sep 13, 2015
Why does the red light stay on now I changed the batteries in my remote?
Sounds like a small price of dirt/mental/ tinfoil might be acting as contact. Remove batts and with clean tooth brush gentle clean all exposed areas, gentle .
Aug 10, 2014 | Dryers
Battery key fob
Turn the ignition key on , open the hood, disconnect the battery for two minutes, reconnect and try .
Dec 14, 2013 | Prestige Remote Start
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
Red lights stays on remote control
If the light on the remote stays on you have a short that will quickly drain the batteries---is issue with the remote light or the one on the set?
Jun 10, 2012 | Vizio L32 32 in. LCD HDTV
One day the remote stopped working. We changed the batteries to no avail. The led lights on both the TV and remote do not light on anymore. The TV turns on/off using the power button and I can also use the...
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Jul 13, 2017 | Insignia NS-27RTV 27" TV
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Problem With Operating the Remote
Check to see that the batteries are installed correct,,may need to reprogram...hope this was helpful...
Apr 23, 2010 | Philips SRU3003 Remote Control
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Vehicle Parts & Accessories Logo
57 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
