Question about Car Audio & Video
Where can i buy a wiring diagram for avic-f500bt to connect to my nd-g500 4 channel amps
Why is my 600watt amp hitting hard but my br as nd new pioneer900 watt is barely makin speakers move I have to turn bass up on radio then it's distorted as nd not hitting at all
First make sure everything is wired correctly, correct polarity and channels. If the amp is a 2/4 channel and 800 watts @ 2ohms, then you would wire your dual voice coil sub at 2 ohms to match the amps output. Same thing if your amp was at 4 ohms, it all depends on how you wire it. Now if your running door speakers off the amp then I would put in an equalizer to better tune it and make sure the amp is set at the proper channels with correct polarity. Double check to make sure your ground,power, and remote wire are getting a good connection
Feb 22, 2015 | Car Audio & Video
HOW DO I REGISTER MY DEVICE NUMBER SO I CAN UPGRADE MY MAP SOFTWARE. MODEL NO AVIC-F500BT
You have to use a usb cord connect the device to the computer and go to the company's manufactor's website.
Nov 20, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Installing Pioneer AVIC-F500BT on-dash NAV
HERE IS A LINK FOR INSTALLATION INSTRUCTIONS
http://documents.victorytechnologies.com//documents/product/16348.pdf
Sep 17, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Wiring diagram ford escort for installing nav system and stereo controls
here is some info:http://www.the12volt.com/installbay/stereodetail/845.html
Apr 13, 2009 | Ford Escort Cars & Trucks
Unlock device for pioneer navigation system
Just earth the parking brake wire and it will think it is on. It is what my installer did.
Mar 18, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Where can I get a installation manual or diagram of installtion?
You can download a manual and other items from the pioneer web site under downloads - at least on the Australian site
Feb 24, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Msn direct status
try getting the new 2.0 firmware on and put it on a SD card, install the new firmware and then install AVIC feeder on ur computer and change the settings to your likeness and save it on ur SD card. your AVIC will ask you to update aka yes or no and click yes, after the first time it will restart and load again with the same ?, click no and go to MSN direct status. keep in mind that the upgrade must take place in the cradle in a msn direct zone.
Feb 09, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Dear Sir I installed a pioneer avic-f900bt as instructed in the manuals.When I m parked the unit works ok but as soon as i drive it starts switching off and on again.I did install the handbrake wire too.
I believe this is a safety problem to prevent distractions to the driver since this unit is installed in eye sight of the driver. Parked position is fine because the parking brake is on signifying you are stopped. Once moving it should turn off multimedia functionality. Try grounding your parking brake cable to think it is always on :)
Jan 10, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Nov 03, 2008 | Pioneer AVIC-S1 GPS Receiver
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
