Question about DeLonghi Coffee Makers & Espresso Machines
From Limerick Ireland have Delonghi Perfecta ESAM5400 machine. "no water" sign is on continuously even with water full. M/C will not operate. Pls advise what I need to do/ where I can get service?
    Sergeant:
  • 236 Answers
Try to tap colse to the switch solenoid as it might just be stuck
Posted on Dec 09, 2016
Testimonial: "Many thanks for the suggestions. I eventually found the float switch jammed. I emptied the tank gave it a shake and the switch released. All now working normally."
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
Hot water tap no longer works. Cleaned out deposits and it still only drips out. What needs to be done. I fear the boiler is corroded or the tap is blocked with calcium despite the water filtering system....
Because the hot water spout is controlled by gravity, it is partially clogged, Here is a little story and see if this helps,Let me know
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 23, 2011 | Bunn VLPF Coffee Maker
How do you descale the machine,as we have no manual
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to clean coffee machine properly? i was given one and want to ensure that it is save from "everything" so i can start using it.
Jun 09, 2011 | Coffee Makers & Espresso Machines
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
