Question about Ovens
My oven of my cooker is blowing cold air. ita akl700.ignis
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Replace the element. It's fairly straight forward.
Posted on Dec 09, 2016
My oven and my grill is not working my fan is still blowing cold air my cooker is a ignis887/701
it could be the control switch or the overheat safety thermal link you would have to take it apart and check if thermal link continuity with multi meter do not try if you are not comfortable using a meter
Dec 09, 2016 | Ovens
Ec600dodlm cooker the main oven is only blowing out cold air
IS IT GAS OR ELECTRIC? IF ELECTRIC YOUR HEAT ELEMENT MAY BE GONE NEED TO REPLACE IF GAS THE PILOT LIGHTS MAY NOT BE GETTING ANY GAS DUE TO CLOGED LINES. ASK SOME ONE WHERE YOU BOUGHT IT TO SEE IF THEY CAN TELL YOU.
Jan 31, 2015 | Ovens
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
The fan only blows cold air and does not heat up any food.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 13, 2011 | Smeg SE399X/5 Stainless Steel Electric...
I have an ew42 hotpoint electric cooker. the oven fan works but only blows out cold air - so it is not working.
You need to replace the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Nov 23, 2010 | Hotpoint Ovens
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
Belling xou178 ss not heating up? fan blowing cold air, digital display working. is it the element and how do i fix it?
Yes most likely it is the element if the fan is still working.
First switch off the power to the cooker. You have to remove the back panel fom the back of the cooker which will give you access to the heating element, disconnect the wires and undo the retaining screws.
Remove the old element and fit the new, reconnect and it should be fixed.
Dec 30, 2009 | Belling Ovens
Oven blowing out cold air
You need to replace the oven element This is located at thr rear of the oven compartment.
If there are no screws securing cover at rear of oven compartment, then you are going to have access it from the rear of the oven cabinet, on the outside.
Hope this helps.
Dec 20, 2009 | Candy Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
