Question about Grilling
What is a coal scuttle - Grilling
    Top Expert:
  • 8,204 Answers
Its a bucket you put coal in and the leave it at the side of your fire place.
Posted on Dec 09, 2016
What is a coal scuttle?
coal scuttle
noun
  1. a metal container with a sloping lid used to carry coal for a domestic fire.
Dec 09, 2016 | Computers & Internet
How do I clean a blocked scuttle drain in 2004 hyundai santa fe?
remove wiper blades and lower windscreen cover drainage pipes should be in far left and right corners also make sure that water is not coming from heater matrix
Jan 28, 2016 | 2004 Hyundai Santa Fe
the wiper mechanism comes out has a assembley from under bonnet remove screen scuttle panel and wiper arm 17 or 19mm nut torx screws for scuttle i think, wiper mech held by bolts at top and clips at bottom which you have to slide to one side with screwdriver.all should now come out as a unit, good luck sliding the clips back
Jun 07, 2013 | 1995 Jaguar XJ6
I added coals to my Charbroil Deluxe 7000 grill, and then they disintegrated. Have I ruined the grill?
Is the grill that you are using gas? If so make sure it is compatible to use with coals. You might also be looking for briquets.
Jul 28, 2012 | Grilling
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Wont start when its wet out.just replaced the coils and module
Check that the drain holes in the engine bay scuttle are not blocked with dirt or leaves etc, because if they block up and the scuttle area at the rear of the engine fills up with water, it can create a short at the electical connections that maybe there. On BMW the computer is there, and when this scenario happens it shuts the power to the ecu and wont start. Hope that helps
Mar 15, 2010 | 1997 Isuzu Hombre
Water sloshing in dashboard
It won't be in the dashboard it will be in the scuttle tray because the drains are blocked.
Lift bonnet, right at the back of the engine bay at the base of the windscreen you will see plastic cowls. The scuttle area is beneath these, there will be a drain either side. It is common for cars parked near trees to get leaves block up the scuttle drains. If you clear them obviously the water will escape... problem solved.
Do this ASAP, if the water level goes too high it will pour in through the heater system and possibly cause damage.
Hope this helps
Lloyd
Dec 04, 2009 | 2008 Kia Spectra5
Gas engineer wants to re-arrange coals correctly post service
yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Feb 05, 2009 | Cozy Heating & Cooling
Grilling Logo
106 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
