Question about Baxter Ovens
I have a problem with baxter oven ov310g powering off automatically. Have to turn breaker on and off again to reset. Any advice?
    New Friend:
  • 14 Answers
It could be a element blown to earth, if breaker is tripping when oven off wiring fault
Posted on Dec 11, 2016
  • Bdog Dec 11, 2016
    It's not tripping the breaker..just shutting down but the clock is still functioning.
  • 87 Answers
SOURCE: no power to the oven, is breaker external or somewhere on the oven?
Go to your breaker box or fuze box and look for a dual circuit breaker It should be labeled stove. Turn the breaker off If a fuze box there usually is a black plastic fuze holder labeled stove pull it out. Confirm at the stove a lack of power.
Posted on Jun 08, 2007
bigg t
  • 640 Answers
SOURCE: Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Posted on Jan 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: F1 error code plus constantly beeps and Oven won't shut off
ERC is bad and must be replaced.
(The Clock).
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 23, 2010
SOURCE: baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Posted on Dec 30, 2011
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
Where is the reset button
All the breakers on an electric OV300 would be accessible from the small access panel on the front lower right side of the oven, there should be a sticker on the door that says something along the lines of "circuit breaker here." If those breakers are all in the up position than it is most likely the breakers in your circuit panel.
May 04, 2012 | Baxter OV300E Stainless Steel Electric...
Baking in the oven, and had a power outage. When the power is restored, will the oven remain "on" - afraid oven will come on while I am away, if power is restored.
The oven will come back on if power is restored. However just turn oven selector switch if applicable to the off position. If it is all electronic then it will automatically reset and not turn on when power is restored. If you need an absolute guarantee to to the breaker panel and turn off the breaker that feeds the range receptacle.
Aug 29, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Baxter ov300e electric oven
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
78 people viewed this question
Top Baxter Ovens Experts
Lawrence Oravetz
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
